How to remove Audi rings badges front and rear
Morning all, just wondered if anyone knows how to remove the Audi rings grille and rear badge because I really don't want to damage anything! Thanks guys
Re: How to remove Audi rings badges front and rear
Think the best way is to get a hairdryer on them to melt the glue then prise off delicately, then some cleaning products to get the excess gunk off.
Mac
Mac
Thanks mac didn't know if the front was held on by anything other than glue, I'll give that a try thanks.
The rear should be ok with the hairdryer, not sure of the front, maybe just pop out???
good luck and let us know how you get on as i might look at swapping mine for black.
Mac
Mac
I saw something somewhere about running something like dental floss behind the badge as you heat it up to slice through the adhesive when de-badging.
For the badges bonded directly to the paintwork Mac is exactly right. Heat up with a hairdryer, get some dental floss and slice through the soft adhesive. You'll then have to clear the remaining adhesive by gently scrubbing away (use some WD40/lubricant so you don't damage the paintwork).
The front RS4 badge is clipped on and you just need to lever from the front at one side of the attaching clips and it should come out. Not sure about the front audi rings though.
Yeah I'm probably gonna do the matt badge thing, just had black optic done and spacers to fit once all done will put pics up
Be careful removing the front. Proper way is to remove the front grille. You can prise out the rings from the housing but there are 12 'sprung clips' to access which are part of the whole Audi Rings and are only made of brittle plastic. There are 3 clips on each outer ring (7 o'clock, 9 o'clock and 11 o'clock when viewed from the front) and 2 clips (6 o'clock and 12 o'clock) on the inner rings.
RS4 B7 Phantom Black
yes but to remove the front grille you gotta remove the bumper, and once its off you can lift on the tabs then follow the steps above... they are weak and break pretty easy. did this when i swapped out my grille... was a paint but turned out pretty well when i was done.caldy wrote:Be careful removing the front. Proper way is to remove the front grille. You can prise out the rings from the housing but there are 12 'sprung clips' to access which are part of the whole Audi Rings and are only made of brittle plastic. There are 3 clips on each outer ring (7 o'clock, 9 o'clock and 11 o'clock when viewed from the front) and 2 clips (6 o'clock and 12 o'clock) on the inner rings.
before
after
2008 Daytona Grey RS4
2007 Forester XT
2003 WRX
2007 GSX-R1000
2007 Forester XT
2003 WRX
2007 GSX-R1000
just break the clips
a new set of rings for the front is about £9
black rings on the back look ace
the front ones just unclip, undo the three screws on top of the grill and bend it towards you and you can reach the clips on the front rings, the back on just peels off but then its hard work getting the backing foam off before sticking the new one on, mark with masking tape to line up new badge exactly where old one was
I'd like to see the front and rear rings painted to match the faux aluminum trim of the grill, mirrors and windows...
a matte silver
a matte silver
Why the S-Line grille?novtec1 wrote:yes but to remove the front grille you gotta remove the bumper, and once its off you can lift on the tabs then follow the steps above... they are weak and break pretty easy. did this when i swapped out my grille... was a paint but turned out pretty well when i was done.caldy wrote:Be careful removing the front. Proper way is to remove the front grille. You can prise out the rings from the housing but there are 12 'sprung clips' to access which are part of the whole Audi Rings and are only made of brittle plastic. There are 3 clips on each outer ring (7 o'clock, 9 o'clock and 11 o'clock when viewed from the front) and 2 clips (6 o'clock and 12 o'clock) on the inner rings.
before
after
I see what you mean, but I don't think the difference would be that noticeable.ArthurPE wrote:I'd like to see the front and rear rings painted to match the faux aluminum trim of the grill, mirrors and windows...
a matte silver
well cause it was free and the old one for some odd reason was peeling and chipped up.... so i just replaced itWhy the S-Line grille?
2007 Forester XT
2003 WRX
2007 GSX-R1000
2007 Forester XT
2003 WRX
2007 GSX-R1000
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 149 guests
