Vabration in dash. Under hard acceleration....
RS4pete
Post by RS4pete » Fri Feb 25, 2011 8:40 am
Thanks for that, I'll give it a go over the weekend :-)
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
RS4pete
Re: Vabration in dash. Under hard acceleration....
Post by RS4pete » Fri Mar 11, 2011 9:32 pm
Ok, so door card off, winder motor, speaker, airbag sensor and foam cover off. I still can't find the bloody vibration :thumbsdown: it sounds like its from the front window cable but even when I tension it by hand the vibration is still there. I've temporaraly stuffed towels by the fuses and up inside the door skin and it's still there! The only thing I can think of now is to try and recreate the resonance of the exhaust at 3k-5k by pressing the pad (no sanding disc of course) of an orbital sander against the internal door skin and varying the intensity. It that doesn't work I might try by using a sound system speaker and a good drum and bass tune :biggrin2:
This is driving me' crazy now!
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
lugars4
Post by lugars4 » Tue Mar 15, 2011 10:40 pm
I found it !!!! after weeks of stress and hating the thing, i narrowed it down to........................Inside the wheel arch.
Basically i tried everything you have from inside the car and NOTHING made a difference, so i figured its outside the cabin.
Took the wheel off and the wheel arch liner. There were 2 plastic pipes, 1 black box and the air filter housing feed (rear one) in there.
I moved them all and made sure nothing was touching and metal pannels or the wing. I couldnt see anything obvious but after that i have not heard it in 2 weeks and am certian i have stopped it (trust me i have tried to replicate it)
Good luck, i know how annoying this one can be, i was so P***ed off i was looking to sell it! :audibash:
I suspect it was the air feed up in the front wing ..... its easy to see once you get the liner off.
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
RS4pete
Post by RS4pete » Tue Mar 15, 2011 10:50 pm
Happy days :-) I'll have a look at mine tommorrow.
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
