Workshop service campaign, definitive list
sonny
Post by sonny » Mon Mar 14, 2011 8:11 pm
I want to create a list of all the workshop service campaigns.
Sometimes these get called "Recalls" it’s only classed as a recall if its associated to a safety issue.
Once we get a definitive list, I shall ask for it to be made a “sticky”
Reason is to help other RS4 owners in the future and use it as reference.
Add to it as you wish I’m sure there are some that I have missed.
PLEASE KEEP IT ON TOPIC
Service Campaigns
17D7: Oil Cooler pipe. Remedy: Double cable tie
53B3: Spare wheel well. Remedy: Insert sealant in well hub
24M4: Fuel pressure sensor. Remedy: N/K
46F2: Replace bolts securing ceramic discs to hub
24H8: SW0800
28E9: Coil Pack, campaign lists that coils numbered 07K 905 715D or F are satisfactory
Steve_C
Re: Workshop service campaign, definitive list
Post by Steve_C » Mon Mar 14, 2011 8:20 pm
Wasn't there a battery related recall?
Gone to the dark side
sonny
Post by sonny » Mon Mar 14, 2011 8:56 pm
Steve_C wrote:Wasn't there a battery related recall?
Its this
53B3: Spare wheel well. Remedy: Insert sealant in well hub (Basically where the battery is, obviously there is no spare wheel either).
lma07
Post by lma07 » Mon Mar 14, 2011 9:31 pm
A few of the saloons suffered from water in the boot lid. Was fixed on request but not sure if you'd class this as a recall?
primus2211
Post by primus2211 » Tue Mar 15, 2011 2:07 am
lma07 wrote:A few of the saloons suffered from water in the boot lid. Was fixed on request but not sure if you'd class this as a recall?
Any write up on how this fix was done? I've the exact issue.
steveyb
Post by steveyb » Tue Mar 15, 2011 1:28 pm
I had this on mine - took 3 visits to sort it out.
Fistly, it was thought it was an ineffective seal around the lights in the boot lid, so both units were replaced.
That didn't cure the problem, on closer inspection the seam welding between the inner and outer skins was noticed to be not continuous (in the area around where the light unit fits). They put in some 'filler' to seal the tiny gaps and when it was hardened they painted over it (you can't tell it has been done). This worked, but only after a third visit to do the other side! Since then no water at all, previously you could hear it sloshing around inside. To drain it out you can remove the 2 rubber plugs at the bottom corners of the boot lid.
sonny
Post by sonny » Tue Mar 15, 2011 3:45 pm
IIRC "water in the boot lid" effected the B6 too, AFAIK there was no service campaign as such for this.
andre3k
Post by andre3k » Tue Mar 15, 2011 4:38 pm
^ I take it then this water ingress problem is what recall 53B3 is all about? Can I confirm from someone in the know that as an avant owner without ceramics, the following should apply: 17D7, 24M4, 24H8, 28E9?
I don't think 24M4 has been done to my car.
lma07
Post by lma07 » Wed Mar 16, 2011 2:20 pm
Re the water in boot lid - Audi replaced the seals round the lights and that solved it (for the saloon)
Craigy
Post by Craigy » Wed Sep 21, 2011 4:32 pm
Hi - Just bought an RS4 and was wondering if anyone out there could recommend a good Audi/RS4 independent garage in the Bristol or North Somerset area (South West), for general maintenance.
Ditched the BMW brand at last - No going back!!!!!!
Users browsing this forum: Google Adsense [Bot] and 78 guests
