Thanks took hours to put them all on.Revolution wrote:jeez, the plod must love you three - i like it though
Didn't have any trouble.
This sounds good, they will be experts when I bring mine inP_G wrote:If they get the practice in on yours Glenn I'll book mine in to be done as well!
Thanks for that info, a real timesaver. I didn't realise the mount was a left hand thread. I took my bumper off to realign last time! it's dropped again a few mm so I tightened the torx and kept turning with bumper in situ, lo and behold up she comes. Saved me a lot of time!!neckarsulm wrote:I've removed 2 x B7 front bumpers this week.
The mounting on the bumper iron is really clever.
You slot the bumper skin into it, turn it clockwise with a long Torx key.
This initially locks the bumper skin flange into the mounting.
Keep turning and the reverse thread on the mounting which locates it into the bumper iron, unwinds itself from the iron and raises the bumper up.
I initially thought that if you were careful you could remove and refit without disturbing the setting but the bumper is locked into the mounting so the adjustment needs to be made every time it goes off and back on as unlocking it messes with the adjustment.
ArthurPE wrote:so you just turn CW to raise once the torx are tightened?
must take some oomph...what tool did you use? a ratchet with extension and torx bit? 3/8"?
neckarsulm wrote:ArthurPE wrote:so you just turn CW to raise once the torx are tightened?
Yes, clockwise would normally wind a thread inwards but the reverse thread means it comes upwards, out of the bumper iron.
It takes surprisingly little oomph but I took the strain off the thread by jamming my knee under the bumper where the aux rad grille is and giving it a bit of assistance.
On some cars the torx bolt can be very rusty so some spray lube down the hole is a good idea.
The hole is way too narrow for a socket, I used a long T30 torx tool with a T handle on the top, same tool as you would use to undo the recessed headlamp bolts (can be seen here in airbox flap DIY page http://www.volkswizard.co.uk/airbox.htm ).
ShouldveBeenAGerman wrote:I did mine as soon as I bought it. The bumper was sitting low and the bonnet adjusters needed a few turns. It now sits perfectly.![]()
Steve_C wrote:Its confusing to me....but then, most things are!
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 351 guests
