Rear brake caliper rewind
5.0 V10 50v biturbo - 571 bhp
Noginthenog
Post by Noginthenog » Mon Mar 07, 2011 3:44 pm
Anyone know where I can get a rewind tool for the rear calipers? (has 3 locating lugs instead of 3)
Noginthenog
Re: Rear brake caliper rewind
Post by Noginthenog » Mon Mar 07, 2011 3:51 pm
D'oh!! Should read 3 locating lugs instead of 2!!!
Noginthenog
Post by Noginthenog » Thu Mar 10, 2011 8:05 pm
For those that need to know there is an elctronic tool required to do this as it rewinds via the same motor that winds the caliper out. Not cheap either.
C6NVS
Post by C6NVS » Thu Mar 10, 2011 9:19 pm
Do you mean Vag-com, or is there something else?
http://wiki.ross-tech.com/wiki/index.ph ... king_Brake
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
VARLEYHYD
Post by VARLEYHYD » Fri Mar 11, 2011 9:23 am
Hi!
New member on here
Also to add;
After recent worn rear pads & disc replaced on mine: I am told that if the diagnostics is not reset correctly the low pad thickness warning does not illuminate at all
G
Users browsing this forum: Fatneck73 and 30 guests
