Bonnet position
KernowPete
Bonnet position
Hi all
I've recently noticed that my bonnet doesn't seem to be sitting quite right when shut. The side edges align perfectly with the edges of the wings, but the front edge seems to be sitting too high, and there is quiet a gap between the edge of the bonnet and the tops of the headlights and grill etc. It's a gap big enough to almost get a finger into, probably half an inch or so where the bonnet meets the front bodywork between the headlights and the grill. At the same time though, it's very securely shut and not at all loose. I'm assuming this probably isn't right? If so, what can be done?
- Revolution
- Trader (Expired)
Re: Bonnet position
From my experience its quite common with cars we get in
Its the bumper thats sitting too low, you will need to loosen it and lift it up a touch.
Bt of a faff but we did it on mine and made a noticeable difference.
Glenn
Glenn
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
- Steve_C
- Top Gear
Re: Bonnet position
Yes, its the bumper out of position rather than the bonnet. This was discussed on here (with photos) around Nov/Dec time IIRC.
Gone to the dark side
KernowPete
Re: Bonnet position
Cheers guys, but won't doing that put it out of alignment with the wings? Or am I being thick?
- Revolution
- Trader (Expired)
Re: Bonnet position
no as youre just hitching it up a little
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
Re: Bonnet position
Sometimes the bumper gets put back on incorrectly and just missing the bracket, it has been known for the bracket to break due heavy handed mechanics
As said it just adjusts using a long torx driver in the top of the bumper. You may have to re-align headlight.
ShouldveBeenAGerman
Re: Bonnet position
The torx undoes the locking bolt holding the adjuster tight, you then need to wind the actual black mount to the desired position and lock it off with the torx bolt again.sonny wrote:Sometimes the bumper gets put back on incorrectly and just missing the bracket, it has been known for the bracket to break due heavy handed mechanics![]()
ShouldveBeenAGerman
Re: Bonnet position
I did mine as soon as I bought it. The bumper was sitting low and the bonnet adjusters needed a few turns. It now sits perfectly.
neckarsulm
Re: Bonnet position
the slam panel/rad support panel/lock carrier can also be on incorrectly and this will cause the lamps to sit low as they are fixed to it.
Re: Bonnet position
ShouldveBeenAGerman wrote:I did mine as soon as I bought it. The bumper was sitting low and the bonnet adjusters needed a few turns. It now sits perfectly.![]()
This really gets on my t*ts,mine looks like yours did on the top photo.Looks way better after the adjustment,is it difficult to do?
Re: Bonnet position
Looking a lot better.
ShouldveBeenAGerman
Re: Bonnet position
It's a bit of a pain TBH, accessing all the bolts that hold the bumper on. You don't need to completely remove it, but it's not far off to get to the winders, make the adjustment and get a snug fit.lofty wrote: This really gets on my t*ts,mine looks like yours did on the top photo.Looks way better after the adjustment,is it difficult to do?
- Ice_Coffee
Re: Bonnet position
according to elsawin the correct gapping is 3.5mm on the sides and 5mm along the top (grille to bonnet)
- Steve_C
- Top Gear
Re: Bonnet position
Thanks, will get the tape measure out on mine as I think it might be more than that.Ice_Coffee wrote:according to elsawin the correct gapping is 3.5mm on the sides and 5mm along the top (grille to bonnet)
KernowPete
Re: Bonnet position
Mines WAY more than that.Steve_C wrote:Thanks, will get the tape measure out on mine as I think it might be more than that.Ice_Coffee wrote:according to elsawin the correct gapping is 3.5mm on the sides and 5mm along the top (grille to bonnet)
I've got the tools sorted and located the adjusters, is it just a case of winding them up until the bumpers in the correct position?
Users browsing this forum: No registered users and 349 guests
