mdm technik ltd
4SRiduA
mdm technik ltd
Post by 4SRiduA » Wed Mar 02, 2011 10:58 pm
Hello,
I am new to this forum and am just after some advise.
My 2006 RS4 is giving me grief and so is Reading Audi. I have a huge steering wobble under braking and knocking from both front sides going over speed bumps. Reading Audi want the car for 3 days!
Mdm technik are a few miles away and was just wondering if anyone has any dealings with them as I can pop in and wait while they diagnose?
Thanks in advance.
Dave.
TOPHOOKER
RE: mdm technik ltd
Post by TOPHOOKER » Wed Mar 02, 2011 11:16 pm
Hi,
I cant give you a reference for Mdm technic, but I think you may have 2 separate issues. Your steering wheel wobble issue under braking may be answered by the post by zedrs5 titled Disc skimming b7, your symptoms sound very similair when braking. Hope this helps in your quest for answers.
neckarsulm
RE: mdm technik ltd
Post by neckarsulm » Wed Mar 02, 2011 11:29 pm
Knocking sounds like DRC
Ice_Coffee
RE: mdm technik ltd
Post by Ice_Coffee » Wed Mar 02, 2011 11:32 pm
Yep you clearly have 2 well known issues with your RS4
1) your brakes are warped, but can be fixed with a skim as mentioned above
2) the famous DRC failure, which audi have promised to fix for free on cars that are less than 5 years old and 75,000 miles irrespective of warranty
RS4KILLA
RE: mdm technik ltd
Post by RS4KILLA » Wed Mar 02, 2011 11:33 pm
recommend mdm technik my ex b5 was maintained by them and remapped by them
B5 S4 KO'4 black saloon sunroof......
B5 RS4 Goodwood Green,sunroof, nav tv, short shifter,
B5 S4 Nogaro saloon
B5 S4 Black saloon,
B5 RS4 Misano red,
B5 RS4 noggy blue,
B7 RS4 Sprint Blue.
B5 RS4 avus silver
P_G
Post by P_G » Wed Mar 02, 2011 11:34 pm
Agreed, knocking is DRC and wobble is pad deposition on your discs. MTM I gather is QST Kim Collins?
Best going to Camberely Audi given your location, universally renowned as RS specialists in the SE region.
S4Player
Post by S4Player » Wed Mar 02, 2011 11:37 pm
It's mdm Pg mate there next to amd technik I'm sure! Mostly do service work on bentleys audi's etc I'm sure
stumpyrs4
Post by stumpyrs4 » Thu Mar 03, 2011 1:07 am
MDM Technik are very very good.
Did my cambelt service.
B5 RS4 - now sold.
4SRiduA
Post by 4SRiduA » Thu Mar 03, 2011 11:35 pm
Thank you all for the reply's.
I took my car down to MDM Technik while on my lunch break. They are based in Marlow (don't think they are next to amd as not in Essex). Website is www.mdmtechnik.co.uk
The wobble while braking is down to the discs, front ones are badly worn and corroded and also pads are low. But more alarmingly he found there was a lot of play on the steering. One of the mechanic and I believe the onwer called Mark (if my memory is correct) found the F**KING STEERING RACK LOOSE.
:shock:
He took the bolt out from the top without the use of any tools! Put some blue locking stuff on and torqued up. We agreed for the rack to be inspected in a week to check it hasn't come loose again.
Has any one had this before?
Knocking noise is down to both front DRC shocks leaking. My car is a 2006 with 54K, would it be covered? MDM Technik said it would also require central valves aswell, is this correct as aren't they a lot of money? Camberley is close to me which is good!
Ice_Coffee
Post by Ice_Coffee » Fri Mar 04, 2011 12:38 am
4SRiduA wrote:Thank you all for the reply's.
:shock:
Your DRC should all be covered, especially if you have FASH, but even if you don't you might have a bit more of a fight on your hands, but audi will eventually sort it out.
sonny
Post by sonny » Fri Mar 04, 2011 10:24 am
Regarding the steering rack I had the same problem when I first purchased the car, symptom was a knocking noise on full lock. Steering rack has been fine since. simple fix. I seem to recall a few owners having the same problem. (think 06 cars too).
Steve_C
Post by Steve_C » Fri Mar 04, 2011 10:28 am
Ice_Coffee wrote:
4SRiduA wrote:My car is a 2006 with 54K, would it be covered?
Should be covered if its < 5yrs old. When in 2006 was it registered?
Gone to the dark side
stumpyrs4
Post by stumpyrs4 » Sat Mar 05, 2011 1:29 am
Mark is the owner of MDM Technik. A young but capable fellow...
B5 RS4 - now sold.
