Coil pack crisis
RS4pete
RE: Re: RE: Re: RE: Coil pack crisis
Post by RS4pete » Tue Feb 22, 2011 8:10 pm
Mine was registered in March 2007 and I have been told it dosen't come under the replacement programme.
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
d10uug
Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by d10uug » Tue Feb 22, 2011 8:56 pm
RS4pete wrote:Mine was registered in March 2007 and I have been told it dosen't come under the replacement programme.
I spoke to audi customer services today as dealer was a bit vague. They said mine wasnt covered by the recall, which has really pissed me off as ive changed 3 coilpacks in 6 months ive even got a spare new one in the boot :roll: Mine is arpil 07
Dougie
RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by HYFR » Tue Feb 22, 2011 8:58 pm
isnt this action about 5 years too late ?
coil packs have been blowing left right and centre for years on the B6 V8
ShouldveBeenAGerman
Post by ShouldveBeenAGerman » Tue Feb 22, 2011 9:32 pm
Audi have now informed me my coilpacks were already replaced so I didn't need new ones. Previous owner experiencing faults so changed under warranty perhaps.
Steve_C
Post by Steve_C » Tue Feb 22, 2011 9:32 pm
Dougie
Mine was reg'd Mar 07 and is booked in for Thursday :?
Gone to the dark side
RS4pete
Post by RS4pete » Tue Feb 22, 2011 10:42 pm
So maybe it go's on build date then, or are they replacing a batch of faulty units using vehicle serial numbers?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
Steve_C
Post by Steve_C » Tue Feb 22, 2011 11:02 pm
I was told it was serial numbers rather than build date - there is a range of faulty serial numbers and until they inspect the car they don't know if yours need replacing.
sonny
Re: RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by sonny » Tue Feb 22, 2011 11:16 pm
Steve_C wrote:I was told it was serial numbers rather than build date - there is a range of faulty serial numbers and until they inspect the car they don't know if yours need replacing.
+1, sounds like dealers talking nonsense again. :roll:
pad125
Post by pad125 » Tue Feb 22, 2011 11:57 pm
I was told this too, in tomorrow will post out come
Dom81
RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by Dom81 » Wed Feb 23, 2011 2:15 am
Spoke to Rob at Camberley today - mine's an April 07, and doesn't need the work
2007 Daytona RS4 Avant
Steve_C
Post by Steve_C » Wed Feb 23, 2011 11:02 am
If there is a cut off date, shouldn't this be based on the build date rather than the reg'd date?
rjkflyer
Post by rjkflyer » Wed Feb 23, 2011 2:25 pm
Mine needs to be done and it's an '06.
This is campaign 28E9 for coil packs which was September 16 2010 initial release in Europe.
The explanation for 28E9: "It is possible that an ignition coil can fail to function, in which case the emissions warning lamp will light up, as designed. In some cases, the customer may also notice that the vehicle pulls unevenly"
The 28E9 campaign lists that coils numbered 07K 905 715D or F are satisfactory, and any other (presumably pre-D suffix) needs to be replaced with an F. Oddly, ETKA appears to list D as latest suffix.
chanchan
Post by chanchan » Wed Feb 23, 2011 3:16 pm
Mines going in next wednesday to have them checked. apparently there are over 189 vehicles affected. I will pass on the relevant details including campaign number once completed.
Again i was told that it was a build issue and not a date issue. they have to check mine against a list of serial numbers and then replace if nessessary.
Rick_RS4
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by Rick_RS4 » Wed Feb 23, 2011 5:43 pm
rjkflyer wrote:Mine needs to be done and it's an '06.
mines in next week for them to be changed, this may explain my emissions light coming on intermittantly on the dash
MSLRS5
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Coil pack crisis
Post by MSLRS5 » Thu Feb 24, 2011 10:48 am
Mentioned this to the dealer and his reply was:
Hi Mark,
I have already checked your chassis against the database and it picked your chassis number out as one of the vehicles which is going to be given uprated/new coil packs.
You should receive a letter from Bianca stating the recall, and we’ll get your car in as soon as the coils arrive.
The way this recall works is that every car between certain dates, that is on the list should be brought in. We will have the correct spec coils in for it. However, what will happen will first of all be a check. For example, Audi state that if coils:
Abc123 or
Abc234 or
Abc345
…are in your vehicle they should not be replaced, but if there is any other spec coils, they should be replaced with the latest coil which could be:
Abc123……..which would be the ones we would have ordered in for you.
I hope this gives you an idea into what is going to happen.
xxxx xxxxx
Service Advisor
Salisbury Audi
Hope this helps...Mark
