Rattling exhaust after removing vacuum hoses
rs4nick
Post by rs4nick » Mon Feb 07, 2011 1:24 pm
Decided to take the plunge and remove the vacuum hoses as per some well documented posts on here - pleased with the resulting sound in lower gears around town :D
However on cold startup during the initial minute or so of higher revs (think running SW090) the exhaust values seem to rattle - can only be heard from outside. Is this normal after the modification? Only lasts less than a minute and then stops
Thoughts?
drcarrera
RE: Rattling exhaust after removing vacuum hoses
Post by drcarrera » Mon Feb 07, 2011 4:16 pm
Doesn't happen with mine. Are you sure you've sealed the apertures properly?
Chris
06 Daytona RS4 Avant (B7)
MB2
Post by MB2 » Mon Feb 07, 2011 4:38 pm
My guess would be either leaking air in the vaccuum pipe as drcarrera suggests or possibly the valves in the exhausts rattling - you can see them if you look down the tailpipe as are right at the front of the exhaust.
rs4nick
Post by rs4nick » Mon Feb 07, 2011 9:05 pm
Pretty sure have sealed vacuum pipes as used grub screw to seal - nice tight fit.
drcarrera - when you say apertures are you refering to the pipes or the diaphragm - have sealed the diaphragm by reconnecting the blocked pipe to it
If just rattling, perhaps lubrication of flaps will prevent it?
Users browsing this forum: Google [Bot] and 93 guests
