TPMS antenna fault epidemic..
neckarsulm
RE: Re: RE: Re: RE: Re: RE: Re: RE: TPMS antenna fault epide
Post by neckarsulm » Thu Feb 03, 2011 8:13 am
Let's agree to disagree. Mine's a weekend driver (and only then when I get the chance) so if I'm heading down a motorway with the family on board and silly speeds a possibility, I'll always check before heading off. I'm not a luddite, but see temperamental monitoring systems as no substitute for a dipstick and pressure gauge...
I use mine like you do yours Dom but that's why I like TPMS.
I know that if there is no warning then there is no danger.
This means that I don't have to fart around on my driveway checking the pressures before I drive off each time, how can that be bad?
Plus while you are on your drive checking pressures, you run more risk of getting car jacked, sad but true.
adsgreen
Post by adsgreen » Thu Feb 03, 2011 8:53 am
Tpms only tells you if there is a problem after the problem has happened.
It won't tell you about other defects such as a nail in tyre.
Also afaik it works on about 4psi drop which is a fair amount and enough to cause extra wear.
Don't get me wrong I think it's good and do use it but it's no substitute for a regular check of the tyres.
neckarsulm
Post by neckarsulm » Thu Feb 03, 2011 10:03 am
In my experience nails usually lead to a slow loss of air which would eventually be noticed.
4psi is still way less than the amount of air loss needed to make the tyre visually look low!
I hate electronic dipsticks as oil doesn't just vanish overnight (or at least without leaving a pool on floor) but air can just go with no trace.
klauster
Re: RE: Re: RE: TPMS antenna fault epidemic..
Post by klauster » Thu Feb 03, 2011 10:26 am
neckarsulm wrote:
mine was replaced under warranty
wiring or antenna?
Anyone got a bill for the work that they can scan up?
I am assuming it's bumper off, swap aerial and bumper back on?
the antenna
neckarsulm
Post by neckarsulm » Thu Feb 03, 2011 11:12 am
Def warranty then!
Did they remove the rear bumper to fit?
klauster
Post by klauster » Thu Feb 03, 2011 11:16 am
I believe they did yes, sounded like an annoying job when they took me through the work etc...
PetrolDave
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: TPMS antenna fault e
Post by PetrolDave » Thu Feb 03, 2011 8:10 pm
neckarsulm wrote:4psi is still way less than the amount of air loss needed to make the tyre visually look low!
+1
With ultra low profile tyres like we have the pressure can be below 10psi and you still won't notice the difference unless you measure the sidewall.
neckarsulm
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: TPMS antenna fau
Post by neckarsulm » Sun Feb 06, 2011 9:48 am
Prob screw your insurance if you crashed due to blow out and TPMS was disabled.
neckarsulm
Post by neckarsulm » Sat Feb 12, 2011 2:02 pm
Update:
A willing guinea pig let me have a look for their TPMS antenna and I found it.
It's located just inboard of the offside exhaust tailpipe
It's hard to see as bracket and antenna will be covered in cack (which explains the failure!)
As suspected, you can pop out the honeycombe panel in the bumper and when you do it's just in front of you and very easy to swap.
His antenna fault cleared straight away but TPMS still not seeing the sensors which I can only conclude is because they are in storage mode from not having communicated with the antenna for a while, I am hoping driving it will awaken them but we shall see.
Pics later
Ice_Coffee
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: TPMS antenna
Post by Ice_Coffee » Sat Feb 12, 2011 3:07 pm
neckarsulm wrote:Update:
Pics later
Is the TPMS antenna just an antenna, or is it also the control unit, I only ask as if you have replaced the control unit it will have to re learn the sensors in the wheels ?
neckarsulm
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: TPMS ant
Post by neckarsulm » Sat Feb 12, 2011 4:19 pm
Fair point, I'd say it's just an antenna otherwise you wouldn't be able to communicate with it when it was broken.
Plus at £60 it's too cheap.
I did a reset and wheel change procedure but no joy
Ice_Coffee
Post by Ice_Coffee » Sat Feb 12, 2011 4:52 pm
point taken
neckarsulm
Post by neckarsulm » Sat Feb 12, 2011 6:25 pm
ice, found an old post of yours and you said yours sprung to life with some driving, is it all sorted now?
did you have the TPMS error warning light on back then?
aled_31
Post by aled_31 » Sat Feb 12, 2011 7:49 pm
My car has been at the stealers for 2 weeks now, they've replaced 4 sensors, 4 valves and the antenae and they still can't get the TPMS to function corrctly. Audi Tecnical UK are now involved and trying to sort. I'm getting really cheesed off at the mo, I've only had the car 6 weeks and its been at the dealers for 2 of them!!
On the plus side, I also complained to the supplying dealer about steering wobble under braking. They diagnosed warped discs and the've fitted new discs and pads upfront gratis!! They're also sorting my airbox flap which is currently non functional.
Just can't wait to get her back!!
Current:
B9 RS4 Avant in Missano
1991 Mk2 Golf GTI 8v, Big Bumper in Oak Green
1960 VW Beetle 1200 (6 volt, 34hp!)
1999 Porsche Boxster 2.5
On Order:
B9.5 RS4 Avant in Daytona
Previous:
3 x B7 Avants in Sprint, Phantom and Daytona (Loved that car!!)
3 x B8 Avants in Daytona, Phantom and Ibis
2 x B9 Avants in Missano (x2), Daytona
1 x B8 S4 Avant in Sprint
neckarsulm
Post by neckarsulm » Sat Feb 12, 2011 8:41 pm
That just leaves the control unit which according to ETKA is in the nearside boot panel and costs a lot more than antenna!
Anyway here is a pic of antenna
Users browsing this forum: No registered users and 1107 guests
