Best injector cleaner for RS4
- Ice_Coffee
what is Rep gr.24? pleaseIce_Coffee wrote:your looking for deviation in values 2 and 4 in measured block 32, you should then do a round of G17, (or if it is really bad G17 at 400% of normal concentration) and re measure block 32, if that does not work additional work is required (but I have not looked into that yet).
error in the instructions
1/4 normal 15 mil
if deviation 4 times as much 4 x 15 ~ 60 ml, but the example says 100 ml?
- Ice_Coffee
- Ice_Coffee
- Ice_Coffee
- Ice_Coffee
thanks, that is helpful
block 32
zone 4 (V8, 2 is for the V6)
the value (whatever it is) must have a deviation <15%
if >15% use 4 times as much
maybe it's the injector pulse width/on time?
if some are on longer (>15% more) than others they are occluded/plugged up???
hmmmmm
block 32
hmmmmm
Ice_Coffee wrote:This is all it has about block 32
Guys, I emptied a bottle of Wynn's Formula Gold Petrol Treatment into half a tank of V-Power and drove the car in a thoroughly spirited manner. The exhaust was fairly smokey at times so something was definitely being burnt off. Driving the car hard ensured that I used up the fuel in the tank quickly and i've just filled up with a full tank of V-Power and the car runs noticeably smoother now, particularly on a cold start. It seems less lethargic and is running quieter now.
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
I use Redex injector cleaner on every other fill up. The amount of cr@p which came out of the exhaust the first time I used this was amazing and in the rear view mirror it was like I was driving a diesel.
The exhaust note is noticably different when using this also - a lot more popping and spitting noises and throttle blipped down shifts give a Group B rally car style bang.
J
J
Users browsing this forum: No registered users and 138 guests
