Stuck exhaust valve
jim1_6310
Stuck exhaust valve
Post by jim1_6310 » Sat Jan 22, 2011 2:48 pm
Sorry for asking this question again but i couldn't find a earlier thread.
Anyways as it says above one of the valves stuck on me yesterday and now i cant get it til open. is there much involved for getting them working again.
Thanks in advance
Jim
sonny
RE: Stuck exhaust valve
Post by sonny » Sat Jan 22, 2011 4:21 pm
Check that one of the vacuum hoses has not come off the rear solenoid flap. It is located next to the tail pipe, you will have to get under the car to look.
Dom81
Re: RE: Stuck exhaust valve
Post by Dom81 » Sat Jan 22, 2011 5:38 pm
sonny wrote:Check that one of the vacuum hoses has not come off the rear solenoid flap. It is located next to the tail pipe, you will have to get under the car to look.
Surely if the hose had come off, the valve would be stuck open?
2007 Daytona RS4 Avant
sonny
Post by sonny » Sat Jan 22, 2011 5:58 pm
Yep your right. :oops:
jim1_6310
RE: Re: RE: Stuck exhaust valve
Post by jim1_6310 » Tue Jan 25, 2011 7:56 am
No hoses are still on it just doesn't want to open for some reason
leont
Re: RE: Re: RE: Stuck exhaust valve
Post by leont » Tue Jan 25, 2011 8:18 am
jim1_6310 wrote:No hoses are still on it just doesn't want to open for some reason
I recently noticed both mine were stuck shut - it took quite a bit of force with a hammer and a long screwdriver to open them back up. I then sprayed the hinges quite liberally with lube. They closed back up again after a few days so I've done the mod to remove the vacuum hoses.
jim1_6310
RE: Re: RE: Re: RE: Stuck exhaust valve
Post by jim1_6310 » Wed Jan 26, 2011 7:44 am
so do you just leave yours open all the time now. Is there anywhere on here which tell you how to do this mod.
cheers jim
Ice_Coffee
Post by Ice_Coffee » Wed Jan 26, 2011 9:01 am
some peeps do, it is a straight forward mod, remove Vacuum hoses ****PLUG VACUUM HOSES**** (Very important), cap off the lugs on the exhaust that the vacuum hoses went to, to stop excess debris entering.
DONE
PS for a moment there after reading your heading, I thought one of the exhaust valves in your cylinder head was stuck closed. I was thinking "thats going to be expensive"
jim1_6310
Post by jim1_6310 » Fri Jan 28, 2011 9:00 am
cheers i might try at if i cant get it til open again
Users browsing this forum: No registered users and 100 guests
