Flaps
Richiehasselhoff
Flaps
Post by Richiehasselhoff » Thu Jan 20, 2011 10:23 pm
In a previous post 'Annoying stuff on our cars' I mentioned that the exhaust flaps opening and shuting at low speed gets on my t@ts and I wish it could be on or off. 'neckarlusm' (I've miss spelled that haven't I) mentioned that it would be good to have it mapped out. Does anyone know if this is possible cos I would luuuv that. Please don't all shout 'Milltec' non valved at me,,,,,,,I'm poor!
Dom81
RE: Flaps
Post by Dom81 » Thu Jan 20, 2011 10:45 pm
Good news is that a map can do what you like - bad news is that it would cost a fair bit!
If you want the flaps permanently open then there's a 5 min mod that does this, and gets you half way to a non-res Milly at zero cost
Let me know if you don't know about this and / or want the link - half the forum have done it in the past...
2007 Daytona RS4 Avant
Richiehasselhoff
RE: Flaps
Post by Richiehasselhoff » Thu Jan 20, 2011 11:01 pm
Many thanks for the reply.
Shows how much I know!
Ideally I would love the flaps mapped cos sometimes you just don't want to be heard.
Would very much like the info on the 5 min mod though!
Thanks again
aidanjaye
Post by aidanjaye » Thu Jan 20, 2011 11:47 pm
The rear flaps have a pipe leadingto them. Simply remove the pipe and plug it but ensure its tight otherwise you'll get a vac leak (not good).
Would also cap the inlet to the valve actuator to stop crud getting in.
Your valves are now fully open all the time!
Richiehasselhoff
Post by Richiehasselhoff » Thu Jan 20, 2011 11:55 pm
Thanks guys, I'll give that a go.
Very helpfull as always
Dom81
Post by Dom81 » Fri Jan 21, 2011 1:18 pm
This is the thread that started it all (and is probably still the best)
http://www.rs246.com/index.php?name=PNp ... ic&t=64387
DuncS3
Post by DuncS3 » Fri Jan 21, 2011 1:21 pm
Yes - great mod and thats the best thread - if you reconnect the tubes and close the valves you wont believe how quiet the car sounds in comparison.
FYI, I did this mod only recently - what I did was I pulled the black tubes of the valves (one was easy, one was hard to get off) - put in some wood screws into the black tube (you have to block those black tubes off to preserve vacumn) and hooked them up within the rear bumper and then put some tape around the exposed end of the valves
Dunc
SimonG
Post by SimonG » Fri Jan 21, 2011 4:01 pm
How many of you have got the flaps perm open?
I got mine closed when it was at the Audi garage a few weeks ago and sort of regret it....
sonny
Post by sonny » Fri Jan 21, 2011 7:25 pm
I love my flaps, God send if you have a none res Full Milltek system. :)
Ice_Coffee
Post by Ice_Coffee » Fri Jan 21, 2011 7:31 pm
SimonG wrote:How many of you have got the flaps perm open?
thats a bit like having a pit bull neutered
Richiehasselhoff
Post by Richiehasselhoff » Sat Jan 22, 2011 2:11 pm
Thanks again guys,
Had a look this morning and found that (for me) the easiest way to plug the hose is to disconnect the rubber from the hard green plastic pipe tucked in the rear bumper. It all pull's down to below the bumper making it easy to work on and comes off quite easily. An electrical socket screw is perfect in the plastic and a large dome head screw in the rubber to keep dirt out. Job done. I'll see what I think.
Users browsing this forum: Google Adsense [Bot] and 102 guests
