A few JHM Parts I was not aware of before
I`m still trying to sell the rs4. I won`t take less than 28 k eur for it and so far potential buyers haven`t shown the interest I find appropriate.
I`m not pressed to sell the car so it will be for sale for as long as it takes for somebody I like to show interest.
I still have the spare manifold with 2 sensors out of which one doesn`t work . I have no idea if the sensors are interchangeable but I believe they are. You can have both of the sensors when I get back home.
Do you think these would look cool ?
I'm sorry about the obnoxious size. I uploaded them
That way so no quality would be lost from hosting on photobucket. Also I don't see an option on photobucket to post them in a smaller size.
Most of the us forums have some sorts of auto size adjust. Is that a forum feature or do I need to turn it on from my user control panel?
http://www.o-brake.com/bremsscheiben_universal.php
If you get a confirmation that these will fit the oem rs4 disc hats please let me know . My email is my username from here + [at]yahoo.com
You can source bolts from either those guys or jhm .
Bolts are one time use btw.
Shoot for 371 mm , they fit in 18 inch rims.
I don`t have the money to do this myself now.
It suggests here they make more normal looking discs for the RS4
http://www.o-brake.com/en_bremsscheiben_original.php
They don't do the wave design for the RS4 unless custom made, only the 'drilled' and 'wet' versions in 380x38mm sizes (that's 4mm thicker than the stock RS4 discs?) if you have a look at the 'our range of discs' tab. Might put an E-mail to them to ask about cost. Rotor hat bolts are supplied with the discs like JHM do.duud40 wrote:http://www.o-brake.com/bremsscheiben_universal.php
I`m saying they show wave discs in a lot of configuration on the site, one of which is 371x34 mm. The only problem would be bolt pattern .
Are you saying you called or emailed and they said they only do wave discs in 380x38 ?
It does not say that on the site.
Down at the bottom on this page : http://www.o-brake.com/en_design_wave.php
Possible dimensions:
â–º Diameter: 312 mm to 430 mm
â–º Thickness: 24 mm to 42 mm
â–º Individual production
Users browsing this forum: Majestic-12 [Bot] and 113 guests
