S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 5:19 pm
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 5:20 pm
is that correct?
xyber
Post
by xyber » Tue Jan 18, 2011 5:58 pm
P_G wrote:xyber wrote:aidanjaye wrote:and no JHM stockist in UK which is a pity.
Satanschild is a UK dealer
There nothing on his site to say that he sells JHM and none of their bits?
He sells 034 gear and gets it from then I think? I've spoken to him about parts before
•••MyProtein Discount code MP486494•••
xyber
Post
by xyber » Tue Jan 18, 2011 6:01 pm
Dannyrs4 wrote:is that correct?
Do [img]http://your%20photo%20link[/img] with no spaces
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 6:12 pm
ok kl thanks for that link seems to be working ok
Timster
Post
by Timster » Tue Jan 18, 2011 8:39 pm
Really like the look of that shifter.... and the install video makes it look pretty easy too.
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 8:59 pm
shifters awesome i would recomend it! its quite heavy tho so you know that your shifting if you get me? good for the bicep i guess ha
P_G
Post
by P_G » Tue Jan 18, 2011 9:02 pm
Cheers Danny. May just the pics but the 380mm discs don't look that much bigger??
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 9:06 pm
might be the picture ill take some more when i get the car back its away in for black optics etc and the new led lights will be on! there definitely bigger p_g they look massive on the car in person
ArthurPE
Post
by ArthurPE » Tue Jan 18, 2011 9:07 pm
to fit 380mm discs (15mm larger) do the calipers need extending brackets?
if not, no braking torque advantage
which really doesn't matter anyways since you always have more brake torque >> tire friction...ie, you can lock them up and you need ABS to prevent such
MB2
- Top Gear
Post
by MB2 » Tue Jan 18, 2011 9:10 pm
I nearly got some of these when was in the US but excess baggage would cost the same as shipping to the UK & with the weight felt sure would have to pay the VAT when I landed so in the end didn't bother. I considered the 380mm discs but in the ended gave up as they would only give 4% advantage, may not fit under my winter wheels, would need to space the calipers out & cost a lot more than their std rotors.
Would definitley try to get a std set of rotors when the time comes though as they look very well thought out vs stock
JHM themselves were very helpful too
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 9:15 pm
i quite like them i think the braided hoses better fluid etc makes a difference all that said i think they'll be coming off shortly for the new ceramics
! they werent that exspensive somewhere around 500 sterling i think which is cheap when considered next to the price of stock discs
P_G
Post
by P_G » Tue Jan 18, 2011 9:37 pm
Where did you get your ceramics from Danny, Doug's 'connections'?
And did you replace the rears with slotted discs in the end as well.
Arthur, they are supplied with spacer brackets to fit the 380mm discs in. Won't go in / under 18's.
S4Player
- Top Gear
Post
by S4Player » Tue Jan 18, 2011 10:12 pm
unfortunately no doug couldnt help me out im going for movit 396 mm 6pot ceramics they look the part as for the rear discs no ive kept the stock ones on at the moment mate
adsgreen
Post
by adsgreen » Tue Jan 18, 2011 11:08 pm
Being able to lock a wheel has sfa to do with sizing brakes for a given application. From what I've seen you could fit the smallest modern disc brake around to an rs4 and still be able to lock a wheel at any speed. The real interest is how they perform near lock up and here generally speaking bigger is better even if torque leverage is the same. Course you need to make sure you're not introducing extra mass that wipes out any advantage you may have.
