Pioneer 9000 BT
Ice_Coffee
Post by Ice_Coffee » Mon Dec 27, 2010 6:15 pm
ok, just to double check, the basic navigation commands are showing up on dis as well.
S4Player
Post by S4Player » Mon Dec 27, 2010 6:39 pm
I never had nav before ice_coffee so I don't know what the basic nav commands were It doesn't display any commands on my dis tho I had a look today just starting to play around with it now it's got endless features! I'll try post some pictures up 2moro of it in my car
Ice_Coffee
Post by Ice_Coffee » Mon Dec 27, 2010 7:12 pm
Cool, the basic commands were things like miles to next instruction, miles to next destination and a large symbol in red (eg a left pointing arrow) indicating what the next instruction will be. You have to keep pressing the set button on your steering wheel to bring it up. Afaik it is the next screen after the second computer screen.
Ice_Coffee
Post by Ice_Coffee » Mon Dec 27, 2010 7:13 pm
I suppose you would have to enable it in vag com
S4Player
Post by S4Player » Mon Dec 27, 2010 7:41 pm
I imagine it could be enabled via vagcom but as it stands just now I don't have it I'll look into it tho and see if I can do it I'm sure we have vag-com lying around somewhere
PetrolDave
Post by PetrolDave » Tue Dec 28, 2010 12:51 pm
I doubt that the Pioneer is accessible with VAG-COM, that normally only works on OE parts.
S4Player
Post by S4Player » Tue Dec 28, 2010 1:02 pm
I'll have a try anyway dave your most likely right tho I've noticed you normally are
Ice_Coffee
Post by Ice_Coffee » Wed Dec 29, 2010 12:00 am
I was thinking more about accessing the little DIS screen, to tell it to enable the nav screen as though it had RNS e installed, or does it not work like that ?
sonny
Post by sonny » Wed Dec 29, 2010 7:39 am
Any pics yet Danny?
PetrolDave
Post by PetrolDave » Wed Dec 29, 2010 5:39 pm
Ice_Coffee wrote:I was thinking more about accessing the little DIS screen, to tell it to enable the nav screen as though it had RNS e installed, or does it not work like that ?
It doesn't work like that.
When the DIS "sees" the navigaion messages on the Infotainment CAN bus it will display them (provided the DIS is coded correctly), but if the navigation system doesn't put those messages on the Infotainment CAN nothing can/will appear on the DIS. And I doubt very much that the Pioneer will generate the necessary CAN messages.
rs32
Post by rs32 » Wed Dec 29, 2010 6:18 pm
My Pioneer AVIC-BT unit (similar but slightly older) definitely does not generate CAN messages to VAG cars. Used in 2 previous R32's and a TT.
Although they can be made to work with steering wheel controls without issues.
PetrolDave
Post by PetrolDave » Wed Dec 29, 2010 6:29 pm
rs32 wrote:My Pioneer AVIC-BT unit (similar but slightly older) definitely does not generate CAN messages to VAG cars. Used in 2 previous R32's and a TT.
CAN messages for the MFSW controls is a completely different thing to the CAN messages for the DIS display.
rs32
Post by rs32 » Wed Dec 29, 2010 7:39 pm
sorry wasn't clear with my original post, I did mean the Pioneer cannot generate the signals for the DIS, or if it can, it wasn't possible to get it working for either an R32 or a TT.
For info, I've also found some of the wiring loom adaptors for the Pioneer units do not support the auto-dimming when headlights are switched on.
Ice_Coffee
Post by Ice_Coffee » Fri Dec 31, 2010 12:45 pm
Thanks to Neckarsulm and petrol dave I now know that you need to recode your instrument cluster to expect the nav commands, according to dave it is,
Add 4 to the value in adaptation channel 62 of the instruments at address 16, using VCDS (VAG-COM).
Ordinarily I would not have thought this would work, but as it turns out there are a bunch of cheap made in china head units that can drive the dis properly, so maybe pioneer included it !
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Dec 31, 2010 4:54 pm
So are you saying that your Pioneer is displaying nav commands on the DIS?
Virdee Autos ~ 07950-526592
Users browsing this forum: Google Adsense [Bot] and 71 guests
