Do Front of Rear Tyres wear fastest ?
MB2
Post by MB2 » Thu Dec 23, 2010 3:57 pm
I know I asked this before, but can't remember/search the answer ! Do the front tyres tend to wear quicker than the rears due to engine weight or do the rears wear faster due to 40/60 drive split ? Want to know which way should be rotating the tyres so they have best chance of wearing evenly.
approved
RE: Do Front of Rear Tyres wear fastest ?
Post by approved » Thu Dec 23, 2010 4:25 pm
i've had mine 10 months and it had new tyres on the front when i bought it.
5mm on the rears, and now the measurements are 5mm front and 3mm rears.
so the wear on mine has beeen consistent across the 4.
i think i'll change them all at the same time this time...
crispy
Post by crispy » Thu Dec 23, 2010 4:51 pm
I've found that the fronts wear slightly faster, but not a great deal in it.
I'd say the wear ratio is about 55/45
I do have quite a good daily commute over the moors, so engine, brakes, steering etc get a good work out most days :D
lengster1
Post by lengster1 » Thu Dec 23, 2010 5:36 pm
Fronts by quite a bit in my experience 60/40 at a guess,inner and outer edges take a beating too on the front
sonny
Post by sonny » Thu Dec 23, 2010 6:19 pm
Front left for some reason :lol:
scottie1979
Post by scottie1979 » Thu Dec 23, 2010 7:54 pm
Im sure i read in the manual that you should swap em round after a while to insure even wear? Nice big tyre bill at the time of replacement though.
PetrolDave
Post by PetrolDave » Thu Dec 23, 2010 8:06 pm
lengster1 wrote:Fronts by quite a bit in my experience 60/40 at a guess,inner and outer edges take a beating too on the front
+1
adsgreen
Post by adsgreen » Thu Dec 23, 2010 8:56 pm
I've just replaced my fronts. Rears still have lots left so agree 60/40 split
bboy
Post by bboy » Fri Dec 24, 2010 6:08 pm
So if the consensus is that the fronts wear slightly quicker than the rears, at what stage would you recommend swapping them over?
Just checked mine and I have 5mm rear and just under 4mm at the front. Given this it would seem that I should be swapping them around soon.
I know that 1.6 is the legal limit but do other forum members swap them over with more tread left? I have P Zeros and I am looking forward to getting them off the car. They seem to really suffer from tramlining.
Have a good Christmas all
Terry1948
Post by Terry1948 » Fri Dec 24, 2010 6:43 pm
I always change mine at 3mm
S4Player
Post by S4Player » Fri Dec 24, 2010 6:45 pm
I've got pzero's on mine and I havnt had any issues and I drive hard on them I'm going for michelins next time out I think tho
PetrolDave
Post by PetrolDave » Fri Dec 24, 2010 7:14 pm
Terry1948 wrote:I always change mine at 3mm
+1
When they're down to that you can feel the grip is less, especially when it's wet or slushy as the sipes don't have the same capacity to take the water/slush away.
amanda1
Post by amanda1 » Fri Dec 24, 2010 8:37 pm
+1
+2 I find swopping 1/2 way helps
Steve_C
Post by Steve_C » Fri Dec 24, 2010 9:37 pm
Dannyrs4 wrote:I've got pzero's on mine and I havnt had any issues and I drive hard on them I'm going for michelins next time out I think tho
+1 but not decided what I'm going for next as it will be a while.
