Help - just had blow out on m40 near beaconsfield
bboy
Post by bboy » Thu Dec 16, 2010 12:01 am
Tyre variants are
AO - Audi only
MO - Mercedes only x 2
Run flat and generic
Apparently they all have slightly different compounds but same dimensions and ratings.
As for ignoring TPMS warnings - guilty. Recently everytime the temperature has gone below 4 degrees I have been getting the red warning. I checked the tyres each time and they were fine so i reset the system. I must admit I just thought it was playing up again because of the temperature. The alert came on just after joining the motorway so i was wary of any change in car handling and there was none. Even after 50 miles the car was still driving fine and not pulling anywhere. Another lesson learnt, if in doubt pull over and check.
neckarsulm
Post by neckarsulm » Thu Dec 16, 2010 8:30 am
I'd be interested to know what was causing the false alarms as there must be a reason, the TPMS is quite simple and quite effective IMHO, it does need VAG COM to be able to troubleshoot it though.
All the time it keeps quiet (without false or real alarms) I can rest assured the tyre pressures are correct, quite often I just get my car out of the garage and don't walk around it so I could easily miss a flat.
adsgreen
Post by adsgreen » Thu Dec 16, 2010 1:00 pm
Also with such wide low profile tyres a significant drop in pressure wouldn't always be obvious as a quick glance
PetrolDave
Post by PetrolDave » Fri Dec 17, 2010 8:01 pm
adsgreen wrote:Also with such wide low profile tyres a significant drop in pressure wouldn't always be obvious as a quick glance
100% agree.
When I had a nail in a tyre about this time last year the TPMS showed a red warning but a cursory glance showed no visible difference between the 4 tyres. Only checking the pressures located which tyre it was, and on jacking the car up and using the "Mark 1 eyeball" was the problem visible.
adsgreen
Post by adsgreen » Fri Dec 17, 2010 8:20 pm
Would be nice if the TPS said which wheel was down but on the other hand it forces you to check all four.
andre3k
Post by andre3k » Sat Dec 18, 2010 2:20 pm
PetrolDave wrote:
bboy wrote:PetrolDave - where did you get a 19" space saver from and what jack do you use?
It's an 18" space saver that I bought from my local Audi dealer, fitted with a Continental space saver tyre. Remember the RS4 could be ordered with 18" wheels so it fits OK over the front calipers, and it has a rolling radius within a few mm of the OE tyres.
I use the genuine Audi jack, also bought from my local Audi dealer, which fits in the "wheel well" to the right rear of the battery. I modified the plastic with the aid of a Stanley knife so it fits neatly in there.
Can someone please explain this to me?!? I ran the tyre sizes (125/70-18, 255/40-18, 255/35-19 & 275/30-19) thru a calculator & the numbers churned out are a ways off?!?
http://www.miata.net/garage/tirecalc.html
bboy
Post by bboy » Sat Dec 18, 2010 4:00 pm
adsgreen wrote:Would be nice if the TPS said which wheel was down but on the other hand it forces you to check all four.
Totally agree. There is a sensor for each wheel so it should not have been hard to change the alert to something wheel specific.
I wonder if there is further information logged in VAG-COM?
'R'e'S'pect_4
jack...
Post by 'R'e'S'pect_4 » Sat Dec 18, 2010 6:01 pm
ordered my jack,
in on Tuesday.
£25
Cheers. :wink:
Users browsing this forum: 666Lenine, Google Adsense [Bot] and 62 guests
