No Cats
No Cats
Post by HYFR » Sat Dec 11, 2010 10:32 pm
Whats the options if you want to risk going no cats ?
how does it sound and does it need to be mapped ?
iR8V10
RE: No Cats
Post by iR8V10 » Sat Dec 11, 2010 10:35 pm
The catless downpipes on the supercharged B7 sounded un-be-<beep>-leiveable!!
In a cab, your ears will bleed! :twisted:
amanda1
Post by amanda1 » Sat Dec 11, 2010 11:01 pm
For a c5 rs6 get it done asap map needed but sounds stunning ...........you will not regret it 8)
Stoffle32
Post by Stoffle32 » Mon Dec 13, 2010 9:21 am
Got a question also, about this in the B7 Rs4, Im thinking of taking the cats out because in SA, we dont have emissions laws and we have really bad fuel so taking out the cats could possibly release some HP!
My question is though would I lose power, because doesnt A high reving N/A engine need some sort of back pressure?
P_G
Post by P_G » Mon Dec 13, 2010 3:53 pm
You would need to remap it to allow the ECU's to compensate for the lack of cats otherwise it will probably run rougher then OEM.
stevomepy
Re: No Cats
Post by stevomepy » Mon Dec 13, 2010 4:58 pm
aka_dk wrote:Whats the options if you want to risk going no cats ?
Hi i sold my RS4 at the beggining of the year - but i had decatted it before i sold it - oh and it also had a full Milltek non res and DMS remap and Gruppe M induction kit - I have no doubt that by decatting it i F###ED the ECU up - which went bang about a week after the DECAT - and god did it go bang - it was under full acceleration when power just completely cut - went into limp mode - could barely manage 20 MPH - teeth onto the steering wheel moment - I had it replaced and remapped and then sold it - but jesus it sounded amazing - pop bang crackle on lift off - dont decat - go for sports cats
S4Player
RE: Re: No Cats
Post by S4Player » Mon Dec 13, 2010 5:04 pm
I've got no cats on my supercharged b7 do it! It's the best noise you'll hear if you go on the srs forum in the events and gatherings section there's two videos off my car from the rr day listen to that then you'll go catless
Ice_Coffee
Re: No Cats
Post by Ice_Coffee » Mon Dec 13, 2010 5:14 pm
There is no feasible way the removal of your cats caused an ECU failure, the closest I can get to in my mind is the CPU working harder trying to compensate for the lack of cats in real time whilst driving, but even then it should be capable of running at full load with no issues, I think it is most likely that your ECU was about to fail anyway.
adsgreen
RE: Re: No Cats
Post by adsgreen » Mon Dec 13, 2010 6:24 pm
Surely the only thing that cats will impact is the post o2 sensor?
P_G
Post by P_G » Mon Dec 13, 2010 6:47 pm
Exhaust gas flow and its rate from the engine? ECU tries to compensate for greater flow through engine by advancinfg fueling / timing to beyond parameters designed in the engine?
lengster1
Post by lengster1 » Mon Dec 13, 2010 7:21 pm
Are you saying removing cats its a step too far P G? Surely not just a step too far for a car that hasnt been custom mapped? My car runs with 2 of its lambda probes inop as part of the mrc map if you have sports high flow cats fitted
karl
Post by karl » Mon Dec 13, 2010 8:26 pm
I'm catless (I've always had an allergic reaction to them anyway...make my eyes go all puffy) and it is AWESOME. Especially in this cold weather, it's loving it. The noise, oh boy, the noise!! As already mentioned, the popping and banging on the overun is superb too and the power is awesome. This is with one of Doug's 'finest range' of remaps of course. It's got to be done!!!!
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue Dec 14, 2010 4:25 pm
Decatting will not cause damage. Because it is loud we now remove the retarded timing start procedure for cat warm up - so it starts a lot quieter and lower revs. Karl - next time yours is in we can update yours to do this.
Milltek make their downpipes with no cats - but don't advertise them as they are "motorsport use only". These mate straight up to stock catback or a milltek.
http://www.MRCtuning.com
Post by HYFR » Tue Dec 14, 2010 10:14 pm
Cheers Doug
Will email for a quote
Whats the penatly for being caught catless ? just a fine?
Ice_Coffee
Post by Ice_Coffee » Tue Dec 14, 2010 10:18 pm
a fine if caught, mot failure + might be seen as an insurance invalidating mod if undeclared
Users browsing this forum: Google Adsense [Bot] and 95 guests
