Would the cold trigger this?
Checked all round at a petrol station and all seems fine, not got my manual in the car, can someone point me in the right direction on how to reset it please.
Tyre pressure warning
RE: Tyre pressure warning
Yes, if the pressures have decreased by around 4 psi compared to the reference pressures against which the tpms was initialised. You may need to set the correct pressures and then record these as the reference pressures.
2007 RS4 Avant in Mugello Blue + Milltek non-res valved, MRC air filter, MRC remap with silent-mode startup
A rough rule of thumb I've found to be about right is 5.5 degrees c for 1 psi change.
So i fyou set them in the summer at around 20c then it's very likely the 0c conditions now will cause the required drop even before you get onto natural loss through time.
I have this problem every winter. The Audi shop have not yet managed to fault find. Additionally, I can time when the warning comes up - usually at 10-12mins after starting the journey. Sometimes the warning corrects itself and sometimes not. I have learned to live with it and wait until the summer. I do think there's a winter / temperature connection but all the pressures are still fine and resetting the computer (to new tyres fitted) makes no difference.
If anyone else has any ideas, I'd like to hear them.
R8 V10 in Sepang Blue
Gone - Sprint Blue RS4 Avant
Gone - Black S4 V8 Avant
I got the TPMS flat tyre wanring yesterday and there was a small self-tapping screw in one of my tyres. Repaired by my local Kwik Fit garage. The system definitely works well in my (limited) experience.
Re: RE: Tyre pressure warning
Might be an idea to check the coding with VAG-COM (Mod 65) - it's a long shot, but you can adjust the sensitivity and a previous owner might have played with it?Bonzo wrote:I have this problem every winter. The Audi shop have not yet managed to fault find. Additionally, I can time when the warning comes up - usually at 10-12mins after starting the journey. Sometimes the warning corrects itself and sometimes not. I have learned to live with it and wait until the summer. I do think there's a winter / temperature connection but all the pressures are still fine and resetting the computer (to new tyres fitted) makes no difference.
2007 Daytona RS4 Avant
RE: Re: RE: Tyre pressure warning
VAG COM will also pin point which sensor is causing the fault
Users browsing this forum: No registered users and 132 guests
