Stuttering and hesitation.
neilc
Post by neilc » Thu Nov 04, 2010 2:04 pm
My Brother has a 2004 RS6 saloon. Had it about 3 months and is experiencing hesitation and stuttering. Been on diagnostics which showed MAF sensor fault. Replaced both internal units with genuine Audi parts. But its no better and nothing else on diagnostics. Car has had new cambelt , plugs etc very recently.
Any advice greatly appreciated.
Neil
drybeer
RE: Stuttering and hesitation.
Post by drybeer » Thu Nov 04, 2010 2:10 pm
I'm sure there is another component to the MAF set up, sadly I'm damned if I can remember what it's called -
CALLING SHOPPINNIT!
You'll know?
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
posterboyj
Post by posterboyj » Thu Nov 04, 2010 2:17 pm
sounds like tired coilpacks
I would scan again and see if there are any misfires. £30 each from Audi x 8
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
delboymafia
Post by delboymafia » Thu Nov 04, 2010 2:17 pm
Hi there and sorry to hear that, where did he get his fuel from, could be dodgy fuel.
RS6Steve
Post by RS6Steve » Thu Nov 04, 2010 3:36 pm
What was done on the service? What plugs were fitted?
Can you post some logs? what are the idle g/s numbers on the Mafs?
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
neilc
Post by neilc » Thu Nov 04, 2010 4:53 pm
The car was serviced by Camberley Audi in July and had a cambelt and major service including plugs etc. Not sure what type. Car is going back on diagnostics this afternoon. Let you know what happens.
2005 Audi TT 3.2 V6 manual in Dolomite Grey with to many mods to mention..
2005 Audi S4 B7 4.2 saloon manual , Phantom black
1995 VW Golf VR6 race prepped track car
http://www.norfolkperformancecarsales.co.uk/
The home of performance V.A.G cars in East Anglia
Previous :
2010 Audi TTRS coupe
2005 TT Quattro Sport in Mauritius blue / black
B7 RS4 Avant Daytona
B7 RS4 Saloon Phantom
B8 S4 3.0T Avant
B8 A4 3.0 TD V6 S-Line Quattro
A4 2.0 T S- line Avant
TT 225
Post by Shoppinit » Thu Nov 04, 2010 5:54 pm
RS6 don't really suffer from coilpack problems.
Look at the MAFs again, make sure they are seated properly. I'm betting on this. The electrical connectors deteriorate, too. What was the daignostics error code?
Have you got access to a vagcom? Or even a generic ODB2 scanner that can show live engine data?
Could also be a vac leak. When you've got the air filter housing off to check the MAF seating, check all the little vac hoses (and also the master cylinder one.
Rupert
Re: RE: Stuttering and hesitation.
Post by Rupert » Thu Nov 04, 2010 6:07 pm
Shoppinit wrote:RS6 don't really suffer from coilpack problems.
I've had two replaced, one on each bank. That was the cause of my O2 sensors going bad. At least that's what they told me.
I suspect my O2 failures had more to do with the oil being over filled.
RE: Re: RE: Stuttering and hesitation.
Post by Shoppinit » Thu Nov 04, 2010 6:18 pm
Yeah, the S4 B6 and S6 have terrible problems with the coil packs. The RS6 by comparison has very few problems with them. No more than the usual background noise.
IRS6I
Post by IRS6I » Fri Nov 12, 2010 3:25 pm
Does it do it under light throttle or when under load (ie low revs, high gear up a hill)
This could be a book leak if the above conditions are correct
Welky
Re: RE: Re: RE: Stuttering and hesitation.
Post by Welky » Fri Nov 12, 2010 3:47 pm
A BOOK leak! Holly <beep>, where's Golfather?!
Oh, nearly forgot... :wink:
C5 RS6 Avant. Muggle Blue, Black leather, PSS9s, Hotchkiss ARBs, Grizz's BIG brake kit, Phaeton cooling ducts.
Users browsing this forum: No registered users and 58 guests
