Digital speedo
goron59
Digital speedo
Post by goron59 » Thu Sep 09, 2010 2:52 pm
In my old '08 A3, I could bring up a digital speed indicator in the DIS display - this is particular useful when abroad as you can set it to km/h.
My '07 RS4 doesn't have this, but wonder if other versions of the s/w do, or if it is something that can be enabled?
Dark red km/h lettering on a black background don't make for easy reading on the analog dial.
ArthurPE
RE: Digital speedo
Post by ArthurPE » Thu Sep 09, 2010 2:58 pm
does the OBC have it?
or is it only the avg speed?
I know the untis can be changed
goron59
RE: Digital speedo
Post by goron59 » Thu Sep 09, 2010 3:19 pm
OBC just does distance, averages etc
Current: 2008 R8 V8, all black.
Previous: 2007 B7 RS4 Saloon, mostly black.
Dom81
RE: Digital speedo
Post by Dom81 » Thu Sep 09, 2010 3:22 pm
Afraid no amount of software updates or VAG-COM enabling will get it for you. I tend to use my Road Angel for speed rather that try to read the dial
2007 Daytona RS4 Avant
goron59
Re: RE: Digital speedo
Post by goron59 » Thu Sep 09, 2010 3:58 pm
Dom81 wrote:Afraid no amount of software updates or VAG-COM enabling will get it for you. I tend to use my Road Angel for speed rather that try to read the dial
I suspected as much, but you never know.
I use a TomTom (which also handily tells you the speed limit), but I'd rather not have a big bit of plastic spoiling the view :(
PetrolDave
RE: Re: RE: Digital speedo
Post by PetrolDave » Thu Sep 09, 2010 4:07 pm
I use my PogoAlert as my speedo, it's more accurate than the analog dial, especially if you have 275/30 tyres.
adsgreen
Post by adsgreen » Fri Sep 10, 2010 9:12 am
PetrolDave
Re: RE: Re: RE: Digital speedo
Post by PetrolDave » Fri Sep 10, 2010 9:58 am
adsgreen wrote:Would this be considered too chav
http://www.360infiniteusa.com/products_ ... xtraid=220
Not in my book - that's a sweet looking gadget.
P_G
Post by P_G » Fri Sep 10, 2010 10:05 am
But only in km. However they do a GPS based HUD for $130 which does kph or mph... :evil: And doesn't require 'professional installation' which I gues is splicing leads in behind the dash.
North_Wind
RE: Re: RE: Re: RE: Digital speedo
Post by North_Wind » Fri Sep 10, 2010 10:06 am
+1 for RoadAngel (dash rather than windscreen mounted). When you are really thrashing it helps not to have to look all the way down to the speedo ... a quick flick of the eyes to the dash is much faster.
adsgreen
Post by adsgreen » Fri Sep 10, 2010 10:10 am
I'm sure it doesn MPH too - the device is european but that supplier is US so can't imagine they will be only MPH.
Also I've been speaking to them - they do an OBD2 cable interface so no wire splicing. Unlike most other devices it's can-bus enabled so even if you do want to mount it better you only need to hook into can high/low and the power options. Personally I quite like the idea of ODB connection as don't like cutting things if I can help it.
'course could go even more chav and fit what I've put in my track car but might be a little... to much for an RS4. ;)
goron59
Post by goron59 » Fri Sep 10, 2010 1:34 pm
I like the HUD gadget - there's an iPhone app that does that too - might give it a try.
Now a new steering wheel - that might be cool :-)
adsgreen
Post by adsgreen » Fri Sep 10, 2010 2:43 pm
The wheel is cool - oil press/temp, water temp, fuel press, speed, revs, gear, lap counter with timing and predictive sector differences topped with a sequential RPM shift light.
Works great on the track... look a bit silly on the road but I'm generally wearing a helmet to so already look a bit of twerp ;)
adsgreen
Post by adsgreen » Sat Sep 11, 2010 4:44 pm
P_G wrote:But only in km. However they do a GPS based HUD for $130 which does kph or mph... :evil: And doesn't require 'professional installation' which I gues is splicing leads in behind the dash.
Aha - got a reply.
- MPH *OR* KPH. It's not switchable but fixed to the unit.
- Shipping is $25 to the UK.
- Unit with OBD cable interface cable included in $179
So about 135 pounds. Considering most other shiftlights/speed indicators need speed and rpm pulses so a 50 quid can-pulse converter this is pretty good value.
More info
http://imagehost.vendio.com/a/16952174/ ... bd-mph.jpg
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 93 guests
