BLUE SMOKE
STURS4
BLUE SMOKE
Post by STURS4 » Thu Jul 15, 2010 8:16 pm
So after a grand total of 3 weeks ownership my RS4 B7 has started to bellow blue smoke.Tickover and reving it smokes like hell.
The car has only covered 19,850 miles and was serviced last week.It is booked in at audi first thing tomorrow.Does anyone have an idea what it might be?would it be covered on warranty?and will i be ok to drive it to audi which is 20ish miles away.
cheers
ArthurPE
RE: BLUE SMOKE
Post by ArthurPE » Thu Jul 15, 2010 8:26 pm
is it running hot?
are you checking the oil level? is is changing?
blue smoke (oil) is bad...I don't think I would drive it...
neckarsulm
RE: BLUE SMOKE
Post by neckarsulm » Thu Jul 15, 2010 8:46 pm
too much oil?
http://www.rs246.com/index.php?name=PNp ... ight=smoke
I have to admit after starting my car up ten times or so to build the vacuum back up while I was testing the power valve I saw some blue smoke when i left it to idle after I'd finished
drcarrera
RE: BLUE SMOKE
Post by drcarrera » Thu Jul 15, 2010 9:35 pm
If it's been doing it ever since the service I'd plump for an oil overfill.
Otherwise,could be a sticky piston ring or something.
As it's still under warranty, should be nothing to worry about regardless of what it is as I'm sure it'll be covered! But as Arthur says I'd be cautious of driving it for fear of making the problem worse (and the fix more expensive!). But if the dealer has said it's OK to drive it in, then I guess just do it!
Chris
06 Daytona RS4 Avant (B7)
tartan_rob
RE: BLUE SMOKE
Post by tartan_rob » Fri Jul 16, 2010 9:40 am
Overfill, sticky relief valve, damaged breather hose etc, etc. As it was serviced around the time it started, if is very likely to be related. Don;t worry, warranty should cover it...
2017 Kawasaki Z1000
2014 RS6
2014 S1
STURS4
RE: BLUE SMOKE
Post by STURS4 » Fri Jul 16, 2010 3:00 pm
Well it got there ok and didnt smoke when i arrived,no overheating etc but for some strange reason the heater was furness hot on 20 degrees then cooled at 18 but still had a hint of warn air coming through.Also some thing i noticed yesterday and today,it didnt run on the choke on cold start.
There's gremlins in the system.
silverRS4
Re: RE: BLUE SMOKE
Post by silverRS4 » Fri Jul 16, 2010 3:13 pm
STURS4 wrote:Also some thing i noticed yesterday and today,it didnt run on the choke on cold start.
If the weather is warm and the "cold start" occurs when the coolant temp is basically the same a warm ambient temp of around 30C (I don't know the exact temp this occurs), the warm-up routine when the engine idle is 1500 RPM for a short while doesn't happen. It doesn't have to when the engine is that warm - even though it is a cold start. What was the approximate ambient when you started the car?
Concerning the smoke...what is the oil level at? And what is the oil temp during your normal driving?
ArthurPE
RE: Re: RE: BLUE SMOKE
Post by ArthurPE » Fri Jul 16, 2010 4:18 pm
perhaps it was overfilled and you burned it off
STURS4
Post by STURS4 » Sat Jul 17, 2010 12:57 pm
I got the car back and they said for an RS its normal for them to smoke on cold start up,as long as it doesnt smoke when warm it will be ok.does this happen to anyone else?
im not really buying that reason,especially when i started it this morning and all was well.i think they have made a blunder somewhere when it was serviced and they fixed it on the quiet.
drcarrera
Post by drcarrera » Sat Jul 17, 2010 1:38 pm
Mine occasionally has a bit of blue smoke when I fire it up but from your desciption you were gettiing a lot, which doesn't sound right to me.
I reckon your suspicions regarding the service are correct!
Chris
rs4v8
Post by rs4v8 » Sat Jul 17, 2010 1:50 pm
Do you park on a hill? I'm not joking here. I've noticed a fair bit of smoke a couple of times after being parked overnight on a steep slope
Current
'10 Nissan GT-R Black Edition, Kuro Black.
'59 Scirocco 2.0 TFSI
'09 RSV4 Factory
'08 Aprilia SXV 550
Car park in the sky
'07 RS4, Phantom black saloon
'57 Clio 197
'04 Aprilia RSVR Factory. Black.
E46 M3 SMG, Alpine white
E46 320i coupe
E36 328is coupe
VW golf VR6
Screw you guys!' - Eric Cartman
STURS4
Re: RE: Re: RE: BLUE SMOKE
Post by STURS4 » Sun Jul 18, 2010 11:21 am
rs4v8 wrote:Do you park on a hill? I'm not joking here. I've noticed a fair bit of smoke a couple of times after being parked overnight on a steep slope
No its parked in the garage or on the drive which is flat.Il keep an eye on it and make sure it doesnt persist.
PetrolDave
RE: Re: RE: Re: RE: BLUE SMOKE
Post by PetrolDave » Sun Jul 18, 2010 11:30 am
With SW 0080 I used to get smoke (black rather than blue) from the exhaust for maybe 30 seconds after start-up (I park on a flat drive) because of the over-rich cold start mixture that 0080 causes.
If your oil level is OK (not over filled), then maybe this is the cause of your cold start smoke?
BTW mine doesn't do it now after I had the engine ECU SW upgraded to 0090.
neckarsulm
Post by neckarsulm » Sun Jul 18, 2010 11:39 am
STURS4, it would have been nice if you'd told us what the oil level was as this is key to diagnosis and simple to do
ArthurPE
Re: RE: Re: RE: Re: RE: BLUE SMOKE
Post by ArthurPE » Sun Jul 18, 2010 4:34 pm
neckarsulm wrote:STURS4, it would have been nice if you'd told us what the oil level was as this is key to diagnosis and simple to do
somebody had to say it ;)
I'll have to get the 090 update
mine hasn't been at the dealer for >1.5 years so I'll have the old stuff correct? would it be 070 or 080?
Users browsing this forum: Google Adsense [Bot] and 122 guests
