b7 rs4 recall - "oil pipe"
Just had my local dealer call for a recall item: "oil pipe."
No more detail than that - anyone had this already, or knows any more info?
The braded pipes that run to the oil cooler, which is in front of all the other coolers, can sometimes chaff leading to (possible) long-term failure. Dealers usually put a plastic ‘hose-holder’ between the pipes to prevent this.
Whilst they’re in the area the tech will also check for leaks from the cooler/hose unions and if found will probably replace hoses & cooler, as the hoses don’t come away easily. It’s a front-off job.
It's not a bad idea to then coat the unions with engine wax to prevent future corrosion before putting the front back on.
"It will never have enough power until I can spin the wheels at the end of the straightaway in high gear."
Mark Donohue on the 1,580bhp Porsche 917-30
- PetrolDave
I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
I've just had all the outstanding Service Campaign work done on my RS4 (paid for by the extended warranty), as well as a DRC replacement due to leaking front shock absorbers.
Dave,PetrolDave wrote:I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
what other SC work did you have done (if you don't mind me asking).
Chris
06 Daytona RS4 Avant (B7)
- PetrolDave
hey bud
I had mine done just after the oil pipes split!! luckily i was only doing a short ttip so noticed a huge oil patch on the drive a few hrs later!
best nit was it was ion for a service 3 days later so they done it and replaced the oil free of charge! 289 quid for a service! now thats value!
happy days!
happy days!
