Got these in the post today
RS6Steve
Post by RS6Steve » Wed Jul 07, 2010 8:14 pm
I let you know how I get on once fitted on friday
Before anyone comments, I did not pay full whack...[/list]
Steve
RS6 gone, R32 gone, M3 gone, Porsche Cayenne Turbo gone, Boring A6 saloon gone, Boring A6 Avant going in 5 weeks :D . Maybe RS5 or S5 Hatchback to come...
iaingbrown
RE: Got these in the post today
Post by iaingbrown » Fri Jul 09, 2010 2:08 pm
OK, I'll bite. Google was my friend and I discovered they are diverter valves. I am none the wiser.Where would you fit these and what would they do?
posterboyj
Re: RE: Got these in the post today
Post by posterboyj » Fri Jul 09, 2010 2:26 pm
iaingbrown wrote:OK, I'll bite. Google was my friend and I discovered they are diverter valves. I am none the wiser.Where would you fit these and what would they do?
The diverter (or recirc) valve will put the boost pressure back into the system to aid the turbo spool up.
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
posterboyj
RE: Re: RE: Got these in the post today
Post by posterboyj » Fri Jul 09, 2010 2:27 pm
RS6Steve, why APR over the Forge valve?
Post by bam_bam » Fri Jul 09, 2010 2:42 pm
Yeah Steve, ^^^ what he said... why for man?
monoi
Post by monoi » Fri Jul 09, 2010 4:14 pm
When you close the throttle, the turbos are still putting out pressure and the air has nowhere to go but back to the turbos and work against them turning. It is obviously not so good for the vanes, and it also slows down the pressure build up for the next time you open the throttle.
The valves either let the air out (the whoosh sound on rally cars) or redirect it in the system so there is less loss of pressure whilst the turbos carry on turning.
I would assume the RS6 is already equipped with those, why change them?
Post by bam_bam » Fri Jul 09, 2010 4:30 pm
Yep, the RS6 has DVs but they're a little average and made out of plastic IIRC. Like Posterboy, I was wondering what the APRs have over the Forge DVs?
RS6Steve
Post by RS6Steve » Fri Jul 09, 2010 5:58 pm
Hi All, my OEM were really old and fluttering... I wanted to replace them with some solid ones that would last a lot longer and be more reliable. Not to say the OEM were unreliable.
Anyway, had them fitted today... And what a difference, it feels like a different car. The acceleration is much smoother and more progressive, feels like the boost is holding a lot better.
So the reason I chose the APR over the Forge was fairly simple. Zero maintenance, lifetime warranty and its a diaphragm not a piston.
Steve
Post by bam_bam » Fri Jul 09, 2010 8:47 pm
Cheers Steve. More reading done, leaning towards adding these to the build list now!
iR8V10
Post by iR8V10 » Fri Jul 09, 2010 9:17 pm
Do these have any effect on power at all?
RS6Steve
Post by RS6Steve » Fri Jul 09, 2010 9:51 pm
Dave, I would say increase in BHP only if the previous ones had failed or were worn. What I can say is my car feels faster and tighter. I'm pretty sure my old ones were shot.
The throttle responsiveness has increase and the speed does not seem to drop off as fast when I come of the throttle. I only did about 5 miles after they were replaced today, but will be back on it again tomorrow.
What I will be doing is going to SRR shortly to see if there is much difference in power.
Steve
500bhp
Post by 500bhp » Sat Jul 10, 2010 9:30 pm
Got a set a Forge on mine fitted by Grizz.
No comparison of the old plastic stock valves.
RS6 C5
RS6 C5, Grizzed
TVR TWIN Turbo Griff.
S8 1998 Audi Motor Show Car. Chipped & Fully Loaded
RS6Steve
Post by RS6Steve » Sun Jul 11, 2010 9:12 pm
The car is running fantastic, I just get the occasional boost 'fart' must a have a slight leak under pressure somewhere! Will check out the hoses tomorrow :-)
Steve
Post by bam_bam » Mon Jul 12, 2010 11:11 am
Haha, boost fart. I'll now have something else to blame my air biscuits on.
paul_23
Post by paul_23 » Mon Jul 12, 2010 2:13 pm
They should not make any more power. If the OEM are working well then there should not be any difference but the OEM diaphragms go weak or fail so upgrades like these get them back to how they should be and last longer. If the OEMs are shot (and you can test them but sucking on one side) then new will make it more responsive - less lag etc.
I got Hyperboost valves which are piston type (like forge) and I am pleased with them, although occasionally I get more than a boost fart - if I floor it and then a car pulls out and i have to back off quickly it seems to not release quick enough and it feels a bit like back pressure lurch ....but it could be something else....
Users browsing this forum: Google Adsense [Bot] and 179 guests
