Just pm'd you.sonny wrote:OK, yes nearly there lol. So hows the car been since the new lease of life?
It's thoroughly addictive to drive now and I spent too much time in it before...
Good luck and pm with your progress.
Only that you seem exceptionally antagonistic Sims.Sims wrote:Did you read the thread on that link? It includes contributions from the people who carried out the work, and quite a few others.scaghead wrote:groundhog day
Did you not learn anything from it?
I am happy to challenge. You have read that thread?Blue_Thunder wrote: Only that you seem exceptionally antagonistic Sims.
Care to give examples,also of where I have praised him. BTW , have you noticed Arthur does not use foul language on that forum, and has reduced it on here? I welcome that.Blue_Thunder wrote: Rather than adding to these discussions in a beneficial way, you only seem to be picking holes in what is posted, particularly when it's Arthur contributing.
Care to give examples, and whilst you are it you may also look for the many instances when Arthur has villified people. Or is that not relevant?Blue_Thunder wrote: Whether you choose to agree or disagree with his posts is up to you, but to try and pull his posts to bits without adding any substance behind your goading just seems pointless.
Blue_Thunder wrote: Rather than have an interesting an mostly factual discussion (as factual as they ever are on these forums), these 'carbon buildup' threads always seem to descend into page after page of playground bullsh1t.
golfather wrote:B7's are full of sh!te....
or should that be B7 owners....
Good point, for I do not subscribe to the theory that RR's are rubbish or conspire against B7 RS4's.SR71 wrote:
The absolute biggest question that no one has even bothered (inspite of my asking a number of times) to answer is how does a dyno cope with the 40:60 torque split in the B7? If it is not measuring the torque individual wheels are generating, the numbers will be suspect...they have to be because you're making assumptions that each wheel is generating the same amount of torque...
I'm convinced that this is a big source of all the anguish.
SR-71, unlike some I am not refuting anyone's data and did remember about SilverRS4's figures hence why I suggested steady state figures have never been recorded pre and post cleaning or with / without porting.SR71 wrote:P_G,
SilverRS4 tested his car over 2 years ago (?) pre and post cleaning (not porting) and measured a 2% increase in g/sec. Everyone forgets about that. We can argue about VAGCOM's accuracy suffice to say if you're going to use it to validate acceleration claims, you ought to accept others using it to validate mass flow rates.
Independent bench tests of a ported manifold's ability to flow more, reveal, funnily enough, better flow although I don't know the raw data, only that when you couple it back up to the engine, you get an improvement of ~10g/sec per bank, which is better than 5%.
Users browsing this forum: Bing [Bot] and 74 guests
