I can see you and sims being kindred spirits...lol
as far as 'unpleasant', you have your moments also
like trolling with an M3 > RS4 post in an RS4 forum for your first post ever, so if you expect me to place any weight on what you say, it's not within the realm of possibilites...
sims also started out a few months ago with deposits and fake power for his first post...he has >700 posts in <3 months...most on these 2 subjects...go figure
'malicious', 'sad'....if we're done with the personal attacks let's get on point...
you are incorrect
the weigts are correct, actual scale weights:
RS4 >3900 (from 6 different sources, including sport auto and rototest)
M3 less than 3600 (from the same, rototest 3544)
period, no wiggle room...FACT
power, several dynos, M3>370 wheel HP, 10% loss from 414
RS4 370 crank as claimed by your reference point sims, and numerorus UK dynos, less 100 as measured by many MAHA runs and rototest, result 270 WHP
which leads to a wt/Hp difference of >55%
yet the cars are the same speed as verified by many, many magazine tests and Ring times...
why don't you explain this?
rather than heap on personal attacks and ignoring the facts
focus! stay on point, don't let your hatred cloud the issue
contribute, don't be negative and angry
dlextreme1977 wrote:
man you seem like quite an unpleasant bloke. Sims comes across as a decent and level minded person, forums are supposed to be a place for some good debate, not quite sure why you are so malicious if people dont agree with what you say. Bit sad really. I actually think that you must be trying to convince yourself and are in denial. If you thought you were right you wouldn't feel it necessary to keep justifying what you say repeatedly like you need somebody to agree with you
Back on topic, i think the reason for your confusion is you are using incorrect weights. Every mag in the uk states 1600 vs 1650kg. Now that may vary a little but that variance could apply to both cars equally. If you use uk weights although you disagree with them- it does explain you're duff calculations. You are telling yourself what you want to here. just my 2p
