RS6 misfiring
RS6 misfiring
Hi, i have a 2003 RS6 Avant with a 512 bhp MTM upgrade and a full Milltek non-resonated exhaust.
It recently developed a misfire problem under load in cylinders 3 and 7, i had the coil packs replaced and this cured the problem.
Two days later the problem is back again this time cylinders 3 and 4, same again coil packs replaced.
Two days later guess its misfiring again. Can someone help??? Thanks
RE: RS6 misfiring
I guess you are getting P0300/16692 along with cylinder specific errors?
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
Possible Causes
Possible Solutions
Cylinder x Misfire Detected (e.g.)
16692 p0308 035 cyl 8
16691 p0307 035 cyl 7
16687 p0303 035 cyl 3
16686 p0302 035 cyl 2
Possible Causes
Possible Causes
- Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18 stuck/open
Camshaft Position Sensor (G40) faulty
Possible Solutions
- Check Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18
Check Camshaft Position Sensor (G40)
Possible Causes
- Ignition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
RE: RS6 misfiring
What fuel are you running? Have you tried filling up somewhere else?
When's the last time the plugs were changed?
+What Grant said - especially vacuum + MAF leaks.
RE: RS6 misfiring
Would be useful if you could log the ignition timing to see if it's being pulled by the ECU. Also MAF values.
I was told that you should always change the spark plugs when doing the coil packs otherwise the packs will fail quickly again
why?
Why??chunky79 wrote:I was told that you should always change the spark plugs when doing the coil packs otherwise the packs will fail quickly again
I assume is due to the faulty coil not making a full/ proper connection with the spark plug. Spark plugs are pretty delicate
Hi Guys, Thanks for all your replies, i had the car diagnised again and its the original cylinders 3 and 7 misfiring again. I will go with the spark plugs for now although they were changed less than 500 miles ago. The plugs were laser platinums, main dealer supplied with chasis number reference. Could it be the MTM ECU remap playing up?
Users browsing this forum: rs4wagon and 97 guests
