80K service + cambelt
Mancmatt
Post by Mancmatt » Tue Mar 23, 2010 10:07 pm
Got price from Stoke Audi of £850 for belt + tensioner, £500 for service and add £290 for water pump + thermostat. Total - £1640 inc. VAT.
Not cheap, but I was surprised when a specialist quote only came in £54 cheaper??
Since a huge portion of the Audi quote is for very expensive labour (they want the motor for 2 days), would one not expect a significantly better price from an independent? I went through just the same with brake disks + pads and had the same result - wasted lots of time just to end up sticking it into the dealer - although I can understand this more as the labour:parts ratio is much lower.
I've been happy with Stoke Audi in the past but wondereded if anyone has made any worthwhile savings by shopping around more? Is it worth haggling perhaps :-)
Would also be keen to hear from anyone who has any horror stories (or positive feedback of course) regarding Audi Stoke.
Chrs.
Matt
RS6 Saloon / Misano Red / KW Suspension.
rob8457
RE: 80K service + cambelt
Post by rob8457 » Tue Mar 23, 2010 11:08 pm
give Grizzy a call he is alot cheaper thats where i will be going when the time comes.
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
Mancmatt
Post by Mancmatt » Tue Mar 23, 2010 11:51 pm
Mmmm. Now I am confused. Wasn't gonna mention names but it was Unit 20 that quoted me £54 less?
grizz
Post by grizz » Wed Mar 24, 2010 7:27 am
Get a full break down on the parts used .... We replace all the parts that the belt moves over ... Water pump & stat..
On the service we replace, all filters , oil & plugs..
I don't want to get into a price war but i cant see how they can do a cambelt for £850 all the correct parts .. I see far too many that only have a telt ......
Unit 20
0151 3366888
Cornishmoocher
Post by Cornishmoocher » Wed Mar 24, 2010 8:14 am
When I went audi (B.G- before Grizz) for a price for a cam belt service, to include all pulleys and tensioners, pump & stat, oils filters and spark plugs, they quoted £4.5k.
grizz did it for about £1500 3 years ago. So if he is now quoting £54.00 less than Audi, A) its £54 less & B) I know who I'd trust to do my cam belt.......
It's all Bollox.
Post by HYFR » Wed Mar 24, 2010 9:31 am
the audi quote will very likely NOT be like for like, and so you are only kidding yourself
Go to Grizz and get it done by a specialist, its what your RS deserves
Post by bam_bam » Wed Mar 24, 2010 9:36 am
I recently had a service at Camberley Audi under the famed Rob C, the engine came out twice (or three times) and it became apparent the whom ever did the cambelt (maybe David K can tell us), made a dogs breakfast* out of it. Off the top of my head, this 'new' cambelt had only covered a couple thousand miles but it was now shot. The cambelt was so loose it could be pulled off by hand and the tensioner had seized. This all preceded me having to pay about £163 for new belt bits, thermy et al (the rest was being done as it was in for a 20k service). I didn't pay any labour, just parts, this was either due to it being under warranty or due to the previous Audi cambelt cockup.
Might be worth ensuring you get it done correctly, could cost you twice over.
grizz
Post by grizz » Wed Mar 24, 2010 9:47 am
The parts required to do a belt change cost £550.00 + vat. The book time to change the cam belt is 8.6 hr @ £50ph.
That does not include the pump or stat.
So The price of £950+vat is a little to cheap as the parts have gone up by £30..and I don't add any extra time for the pump or stat.
If a quote is cheap there is a reason.
Unit 20
0151 3366888
Re: RE: 80K service + cambelt
Post by HYFR » Wed Mar 24, 2010 9:51 am
bam_bam wrote:and it became apparent the whom ever did the cambelt (maybe David K can tell us)
that was Stafford Audi in June 09
more weight to the specialist and not a monkey in a uniform
vikingrs6
Post by vikingrs6 » Wed Mar 24, 2010 10:00 am
bam_bam wrote:I recently had a service at Camberley Audi under the famed Rob C, the engine came out twice (or three times) and it became apparent the whom ever did the cambelt (maybe David K can tell us), made a dogs breakfast* out of it. Off the top of my head, this 'new' cambelt had only covered a couple thousand miles but it was now shot. The cambelt was so loose it could be pulled off by hand and the tensioner had seized. This all preceded me having to pay about £163 for new belt bits, thermy et al (the rest was being done as it was in for a 20k service). I didn't pay any labour, just parts, this was either due to it being under warranty or due to the previous Audi cambelt cockup.
Out of interest are there any 'symptoms' of a badly done cambelt other than it all goes bang?!.. Anything to watch out for?..
RS6 C6 - Stock atm but will be getting an MRC Stage 2 shortly
RS6 C5 - H&R'd and MRC'd Happy Days!..
Mancmatt
RE: Re: RE: 80K service + cambelt
Post by Mancmatt » Wed Mar 24, 2010 10:04 am
I'm not trying to start a price war but I guess I hoped that with a labour intensive job there may have been bigger savings to be had over the stealers.
I've no doubt in your ability Grizz to do the job properly, especially given the feedback on here. Just to clarify, the £ 850 tag was belt + tensioners. With pump and stat included would be £1140. Is there a long list of other parts that you guys would also replace?
My first job for sure is to clarify the full list of parts included in the dealer price for the cambelt + 80K service. I need to be sure that I am comparing like with like.
As for the 4.5K quote mentioned - they must av been taking the p**s. I guess you walked in with a Versace suit on or something :-)
vikingrs6
Re: RE: Re: RE: 80K service + cambelt
Post by vikingrs6 » Wed Mar 24, 2010 10:07 am
SuicideAl wrote:I'm not trying to start a price war but I guess I hoped that with a labour intensive job there may have been bigger savings to be had over the stealers.
I think it would be useful for future reference to publish a full breakdown of parts / part codes required for a full cambelt service with any other items that should be changed / serviced while their in there.. can we have a sticky please?..
grizz
Post by grizz » Wed Mar 24, 2010 10:11 am
The camshafts are out of time.. We see sooo many that have used tip ex to mark the pulleys and not the correct pin and bar.
If any one of the rollers were to collapse the belt would become slack and jump teeth. This would result in a dead engine.....
Unit 20
0151 3366888
A20LEE
Post by A20LEE » Wed Mar 24, 2010 11:03 am
grizz wrote: We see sooo many that have used tip ex to mark the pulleys and not the correct pin and bar.
dealers did this on mine, it was discovered when the thermostat failed and the whole cambelt change had to be done again.
the6
Post by the6 » Wed Mar 24, 2010 11:37 am
I had some work done by Audi, see the invoice. Sadly I didnt get teh thermostat done at the same time DOH!!! Make sure you do.
I don't want to seem like I'm sticking my oar in but this was a seriously good and competative quote, Im now due for the 80K service with the plugs etc and the same branch quoted me £750 + VAT! COME ON FFS!!
Just as much to do the cambelt/tensioners and pump according to them! As it happens and indy (one of two should should only use), they hit me with £515.00 PERFECTO.
Anyway all I would say is bear in mind Audi garages all have different prices where labour is concerned, some perhaps on the parts looking at what I was charged.
You can hound out a deal, if you need it, monkeys in suits perhaps at Audi, but it's all above board, guaranteed and my warranty likes that sort thang.
Good luck.
Users browsing this forum: asgor, javier_gl, Macada123, srichards and 66 guests
