Carbon build up?
- rothschild
Carbon build up?
Hi to all, I'm new here, but I've been reading the forum for a long time now. Here is the problem. I'm well aware of carbon build up problem on our cars and as most of you guys was sort of hoping that it won't necessarily apply on me in any way. But I guess it did.
A 2007 Rs4 with Less than 19k miles on the clock. The car still feels alright and not slow but that surge of power after 5500 rpm isn't there anymore. What happens is it just climbs up the revs with probably the same pace as it does before the 5500 rpm mark. No codes or errors, no detonation or pinging. So what do you think guys? Carbon or carbon not? =)
RE: Carbon build up?
more likely vacuum leak or problem with the flaps in either the inlet manifold or airbox.
nope, sounds like it needs a software update, and the vaccum checked for air leaks, faults etc... mine got sorted, and mine was acting very similar to yours
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
I would look at the soleniod that opens the flap in the airbox,mine was replaced under warrenty at 26k,if your epc light ever comes on then the vanes in the inlet manifold are probably gunked up,mine had a new manifold at the same time,i put it down to the previous owner not revving it that high that often!!
- rothschild
David, what were the two sensors that were replaced?davidkoulakis wrote:Carbon![]()
Mines on 70k....it had lost its power kick after 5.5k rpm
had it in Audi for 2 weeks
two sensors replaced linked to the vacum/manifold type area
hey presto, power kick at 5.5k RPM is back and car is fast as f**k
answer = not carbon
He has an opinion, but (as far as I'm aware) no first hand experiencescaghead wrote:sims is your man on this one
Closest you get for that is Pippyrips, who had work done to remove and prevent the buildup. He ran the same figures on a dyno (same day) as rAudiguy who'd had similar mods but no decoking, and from what I hear the deposits returned anyway
If Rob's not around, SR71 can advise on the work done to the car
2007 Daytona RS4 Avant
- rothschild
still hereDom81 wrote:He has an opinion, but (as far as I'm aware) no first hand experiencescaghead wrote:sims is your man on this one
Users browsing this forum: dan32v and 205 guests
