Difference between PS2 and PS2-R01
estrop77
Post by estrop77 » Thu Feb 25, 2010 10:26 pm
i thought michelins were fine on the back but a problem on the front. i had normal ps2's on the back with the big rim rim protectors and they were fine
Rich
RS6 Saloon - 03 Mugello Blue / Silver. Fully loaded. Standard and mint used at weekends only.
andyt
Post by andyt » Thu Feb 25, 2010 10:31 pm
This is the wear on the fronts, which meant they had to be replaced somewhat prematurely. You can see that the wear is even across the face of the tyre and then there's just a lot of rubbing on that one inside bit.
Daveperc
Post by Daveperc » Thu Feb 25, 2010 11:35 pm
That is classic rubbing on the "Knobbly bit" - ie it is fouling on part of the suspension.
I would say that you have a good case to argue that the supplier has given you the wrong tyres for the RS6
Dave
Post by Shoppinit » Thu Mar 11, 2010 9:57 pm
andyt: came across this which explains the issue:
SteveH wrote:I'd given them the part number previously posted on here and wikipedia as "14875", but they advised this was an american product code. The uk tyre specifically manufactured for the RS6 is "255/35/ZR19RS6XL, code 054277". If that tyre is not ordered by your local tyre dealer then you have a high risk of the tyre rubbing on the front suspension, which I've previously experienced.
http://rs246.com/index.php?name=PNphpBB ... helin+code
marmite
Post by marmite » Sat Mar 13, 2010 12:36 am
I have ot R rated Conti's
the X load tyres I had before were not avaliable any more
Porsche run 'N' Ratings
Merc 'M' Rated
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
Users browsing this forum: Google Adsense [Bot] and 133 guests
