agreed, don't know about the brakes, only if you were tracking it if not then the stndard rs4 brakes are good enough.stumpy67 wrote:Brakes
ARBs
Exhaust
Custom Map
Job's a good 'un.
Expert mods
Re: RE: Expert mods
RE: Re: RE: Expert mods
Thank you all.
My car already had:
Revo map
Forge
Milltek complete line
KN air filter
Now following you(your fault, hehehe):
H&R ARB`s on the way
B7 front and rear on the way
short shifter on the way
My car already had:
Revo map
Forge
KN air filter
- rsmonkey918
My car also had Forge DV's fitted- neither of them were working properly at first service/health check at MRC- its not a given that aftermarkets are the best- Doug recommended the 710's from the S3 as the diaphragm was more flexible with less inertia= better throttle adjustability. No fault codes were flagged up at either this, or succeeding 6 monthly services/oil changes......
Steve
2000 X RS4 B5 Avus short shift, MTM/full Milltek to 460bhp, 19" Audi split rims/BBS CH's in anthracite, B7 front/rear big brake conversion, H&R ARB's/Bilstein PSS9's/ESP gearbox brace, retrofit RNS-E+Nav, ITG/MRC panel filter
2007 '07 Smart Brabus 101bhp, Bilsteins, Bentley Silverlake
2007 '56 Aprilia RSV Factory for some weekends
2004 '53 Honda Rune NRX1800 for other weekends
What about the airbox mod ? have you done it?
- 5th Gear
ditch the forges for 710n,s and throw the revo in the bin and get an mrc remap
665 bhp + 586 lbft...
- rsmonkey918
Had the airbox mod and panel filter combo done in September- difficult to detect and more power, possibly a bit torquier but definately smoother and a nice steady build up of ooomph......
Steve
don't forget the support brackets for the h&r arbs unless you want some cracked subframes
the popular other option are the hotchkis arbs that include brackets are are cheaper - some say they are not as stiff but there is not much in it from what i can tell
Re: RE: Re: RE: Expert mods
Thank you, from where do you usually buy the support brackets?frazered wrote:don't forget the support brackets for the h&r arbs unless you want some cracked subframes
RE: Re: RE: Re: RE: Expert mods
Guess that I will do the airbox mod and will try the 710 n`s
mrcphilport wrote:Thank you, from where do you usually buy the support brackets?frazered wrote:don't forget the support brackets for the h&r arbs unless you want some cracked subframes
- Top Gear
I bought billet Hotchkis support brackets from Unit 20 after my H&R arbs tore my rear subframe to sh1t.philport wrote:Thank you, from where do you usually buy the support brackets?
Make sure you get brackets before you fit the H&R ARBs otherwise you could be looking at a very expensive repair job.
In trying to save myself £140 on the support brackets in the first place (by thinking my car would be ok with the ARBs on soft setting) I ended up having to fork out hundreds for the brackets and related repairwork to the subframe.
Finally I´m following your oppinion, my ecu is at MRC for a stage 2, can´t wait to give you some feedback, anyway, before I get it you are guiltyjimbo1234567 wrote:ditch the forges for 710n,s and throw the revo in the bin and get an mrc remap
