The issue does affect all FSI engines:
http://www.audizine.com/forum/showthrea ... Megathread
Its just that no one cares whether a 1.6FSI engine makes 100 or 110hp...you don't buy the car for that reason.
On this thread you will see Arthur writing the same stuff:
http://www.audizine.com/forum/showthrea ... p-Clean-Up
The issue is clearly gaining traction in the US. We are away behind here in the UK.
His best line in that thread is:
Whilst he lays claim to his engineering credentials, he has not taken a single measurement in support of his contentions. About the only thing he has measured is acceleration...using the onboard laptimer and the Mark 1 eyeball.I seek no quarter, nor compassion or understanding...you do not exist to me, and vice versa...so save the psych 101 for someone who gives a crap and has a modicum of respect for what you say...you have been sadly mistaken if you think I give a %&^$
He glosses over the fact that another poster has found that the times registered by this method and using VAGCOM differ by ~0.5secs. So, the previous thread on this site dealing with acceleration times...you all ought to add 0.5 secs to your times if you've used the onboard lap timer...
But thats not really the point...
You can see US owner after US owner contributing to the aforementioned threads talking about the state of their manifolds, the constant CEL lights, the recovery of hp post cleaning and Arthur still digs his heels in.
Remember, even VAG engineers have written:
The most telling thing for me is that Arthur contributes next to nothing else on this forum or any other.Directly from the technical staff of VAG is complete acknowledgment of the FSI intake valve deposit issue, and it's impacts, including: decreased performance, misfires, catalytic converter damage ... etc.
"Gasoline engines with direct injection of the fuel into the combustion chamber, i.e., not into the intake port, suffer especially from the problem of the formation of carbon deposits on components. Carbon deposits form especially in the neck region of intake valves. A more exact analysis of how these carbon deposits form leads to the following result: Oil and fuel constituents first form a sticky coating on the components. These constituents are chiefly long-chain and branched-chain hydrocarbons, i.e., the low-volatility components of oil and fuel. Aromatic compounds adhere especially well. This sticky base coating serves as a base for the deposition of soot particles. This results in a porous surface, in which oil and fuel particles in turn become embedded. This process is a circular process, by which the coating thickness of the carbon deposits continuously increases. Especially in the area of the intake valves, the deposits originate from blowby gases and from internal and external exhaust gas recirculation, and in this process, the blowby gasses and the recirculated exhaust gas come into direct contact with the intake valve."
"Especially in the area of the neck of the intake valves, excessive carbon deposits have extremely negative effects for the following reasons: In the case of Otto direct injectors, the successful ignition of the stratified charge depends to a great extent on the correct development of the internal cylinder flow, which ensures reliable transport of the injected fuel to the spark plug to guarantee reliable ignition at the spark plug. However, a coating of carbon deposits in the neck region of the intake valve may interfere so strongly with the tumble flow that ignition failures may occur there as a result. Under certain circumstances, however, ignition failures can lead to irreversible damage of a catalytic converter installed in the exhaust gas tract for purifying the exhaust gas. Furthermore, the coating of carbon deposits in the neck region of the intake valve causes flow resistance, which can lead to significant performance losses due to insufficient cylinder filling, especially in the upper load and speed range of the internal combustion engine. In addition, the carbon deposits in the neck region of the intake valve may prevent correct valve closing, which leads to compression losses and thus sporadic ignition failures. This in turn could irreversibly damage the catalytic converter. There is the potential for small particles to break away from the coating of carbon deposits in the neck region of the intake valve and get into the catalytic converter. These hot particles may then cause secondary reaction and corresponding local damage of the catalytic converter. For example, a hole may be burned in the structure of the catalytic converter."
"Globular deposits are found especially on the valve stem downstream from a partition plate in the intake port. Due to the dripping of high-boiling hydrocarbons from the partition plate towards the valve neck or valve stem, globular carbon deposits eventually form there by the sequence of events explained above. These deposits on the valve stem can result in flow deficits due to undesired swirling and turbulent flow around the globular carbon deposits. This may persistently interfere with the formation of stable tumble flow from cycle to cycle."
Yet he pops up time and time again on Audi forums all over the WWW whenever anyone questions why their FSI'ed car is down on power.
Call me suspicious but if that doesn't suggest that he does have an agenda, I don't know what does?
Lastly, inspite of his claims to have observed the nil effect of carbon buildup in FSI engines, he has not posted one single controlled experiment to support his contention.
(After all, it'd be easy for someone like him to take some measurements, open up his manifold and clean it, and take some more....oh wait, how many people have already done that?)
Au contraire, there are dozens and dozens of cases of owners out there who have gained substantial levels of performance back post-cleaning. Certainly all our local owners here in the UK rave about the performance of the car post cleaning.
The general consensus is that as a result of carbon build-up, through a mechanism that no-one really understands, the car pulls timing, which combined with a slightly reduced mass flow rate, all contributes to reduced power.
Surely, we can agree that the debate is about how such an issue should be combated?
Anto simply disconnected his knock sensors but that is a little extreme for most of us...
