Timing chains AGAIN!!!
quattrokid1
Re: RE: Timing chains AGAIN!!!
Post by quattrokid1 » Sat Aug 01, 2009 10:37 pm
tweek wrote:Interesting, the only thing I can think of is the S4 is the only V8 that has 40 valves, all the other V8's only have 32 valves.
Curious that the new V8 engines are all 32v. This is only my view of what could be the cause and maybe completely wrong, comments welcome.
Pete
are you sure? I thought the RS6engine was also 40v heads??????
B7 RS4 is 32 because its got direct injection and as R8 etc.
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
R33
RE: Re: RE: Timing chains AGAIN!!!
Post by R33 » Sat Jan 30, 2010 10:07 am
What's the normal service interval for changing the timing chains, and how much does it cost?
elmo
Post by elmo » Sat Jan 30, 2010 2:07 pm
From other threads on this site, I believe the chains need servicing around 100,000 miles. Don't think it necessarily means a new chain, but guides and tensioners are well worth doing at this interval.
I don't know how much this would cost, quite a lot I should think, as it is an engine out job by the look of it.
I would probably budget £1,500 as a minimum at an independent specialist, and more if you want a main Audi Stealer to do it. Bt I am sure that someone out there has got a proper figure.
04 Audi S4 B6 Moro Blue Saloon
Peugeot 205 MI16 with twin 45's for the track (in the Garage)
Honda Prelude 2.2Vti - Gone but not forgotton
TR7 - well rid of
Triumph Spitfire - student wheels
BlingBling
Re: RE: Re: RE: Timing chains AGAIN!!!
Post by BlingBling » Sat Jan 30, 2010 3:46 pm
R33 wrote:What's the normal service interval for changing the timing chains, and how much does it cost?
Never unless necessary
quattrokid1
Post by quattrokid1 » Sat Jan 30, 2010 6:46 pm
I think the newer engines has 32 valves because these are direct injection and therefore the injector takes the space the 5th valve would have used...
somethin' like that anyway:)
according to Grizz around 100,ooo miles and its an engine out jobbie as you can see in the above photo
Audi 100 2.2E SOLD
Vorsprung_Durch_Technik
Post by Vorsprung_Durch_Technik » Mon Feb 15, 2010 9:44 am
I have been thinking..... dangerous game but well.... ;)
My S4 is nearing 80K on the clock and has the tensioner rattle on startup, although frequent oil changes seem to keep it pretty unnoticable. However as I intend on keeping the car for a few years is it worth having the tensioner and guides done at 100K?... thoughts welcome. thanks :)
verysideways
Post by verysideways » Mon Feb 15, 2010 10:44 am
Get the tensioner and guides done when the noise stays even after start up. I had a long chat with Doug at MRC about this as mine's just been in for a clutch and so half the labour to pull the engine out was already done.
IIRC he said that the start up noise is not unusual, it's when it continues to make the noise then you are looking at tensioner failure, and then you're looking at anything up to £1500 in parts (depending on which bits need replacing).
2003 B6 S4 Avant 'chase car'
Petrolhead Tours Driving Holidays
Post by Vorsprung_Durch_Technik » Mon Feb 15, 2010 2:45 pm
thanks for the reply yeah I will do that, I dont suppose thats too excessive in terms of parts, its the 20 hours labour involved thats possibly more worrying!!!! However the car is covered by extended warranty, I cant see how, as this is supposed to be a serviceless system, that such a failure would not be covered...Knowing any warranty policy thought they would probably find a loophole!!!
