Aftermarket Brake Pads
stumpyrs4
Post by stumpyrs4 » Tue Feb 09, 2010 12:02 am
B5 RS4 - now sold.
P_G
Post by P_G » Tue Feb 09, 2010 12:05 am
I have looked at those a few times but as I do not know Brakeworld from Adam I steered clear.
sonny
Post by sonny » Tue Feb 09, 2010 12:59 am
P_G wrote:Standard at present sonny, it is Jim who has the larger 380mm front disks which wouldn't solve my rear disks warping!
Okay cheers, what was the make of the 380mm disks do you know?
P_G
Post by P_G » Tue Feb 09, 2010 8:43 am
They are Brembo too. Larger holes and 4 in pattern rather than 3 pattern. Pretty pricey through IIRC £1800 for the disks, brackets to mount them and EBC yellowstuff pads plus fitting. So the discs are probably £1200-1400 in that equation?
caldy
Aftermarket pads
Post by caldy » Tue Feb 09, 2010 9:07 am
I think Jim went with Pagid RS29 Yellow at £500+ - not cheap by any means. Here are a few options for you..........They're all pretty helpful and in various stages of reporting back to me on their recommendations for the RS4.
For Ferodo DS2500:
Camskill ( Jim ) 01946 518201
Performance Parts Direct 0845 3451487
Circuit Supplies ( Tim ) 01525 385888
For Pagid RS14, RS15, RS29
Performance Braking 01600 713117
K300 0161 3551275
Although I've only done 5k miles I'm gonna renew my pads prior to the European trip.
RS4 B7 Phantom Black
sonny
RE: Aftermarket pads
Post by sonny » Tue Feb 09, 2010 11:07 am
Thanks for the info there, I came close last year to ordering the RS15's but was put off as there was no sensor.
Might just go for the EBC's
duud40
Post by duud40 » Tue Feb 09, 2010 11:40 am
I don`t think the pads having no sensor is such a big problem...
Since the calipers are quite big you can just steer max left or right and just take a look at the pads and see how much material they have left . Takes maybe 5 minutes and you don`t have to get dirty.
caldy
Pad wear indicators
Post by caldy » Tue Feb 09, 2010 12:27 pm
x 2.
stumpyrs4
RE: Pad wear indicators
Post by stumpyrs4 » Tue Feb 09, 2010 1:44 pm
x3
B5 RS4 - now sold.
P_G
Post by P_G » Tue Feb 09, 2010 2:17 pm
No doubt it is easy to view pad wear but it defeats the purpose of having a system that is already installed on the car and not using it or trying to trick it. Each to their own on this occassion.
Sims
Post by Sims » Tue Feb 09, 2010 7:30 pm
P_G wrote:No doubt it is easy to view pad wear but it defeats the purpose of having a system that is already installed on the car and not using it or trying to trick it. Each to their own on this occassion.
I agree. Do the Pagid RS29's have sensors? I am quite keen to learn how much better they are than the standard pad.
Billy
Post by Billy » Tue Feb 09, 2010 7:40 pm
No they don't mate.
duud40
Post by duud40 » Tue Feb 09, 2010 7:44 pm
I wasn`t saying that if you have to choose between the same pad but with sensor or w/o sensor you should choose the one without the sensor.
I was merely saying that it broadens the option range.
Plus I think there is quite a substantial difference in cost for a simple wire and a connector (sensor) .
Sims
Post by Sims » Tue Feb 09, 2010 7:51 pm
Billy wrote:No they don't mate.
Thanks. I assume this is about the RS29's having sensors.
How much better are the RS29's over the standard pads?
iana74
Post by iana74 » Tue Feb 09, 2010 8:03 pm
I think it's actually the pads without sensors which cost quite a bit more. I think it depends what you need out of your braking system, regular road use with some "spirited" driving then OEM or something like the EBC would suit. Depending on where and at what cost you can source OEM..... I may be wrong but I think the Pagids are substansially more and you would really need to be tracking the car etc to justify the cost, unless you've got plenty of cash and just fancy them of course!
I'm also happier having the same pads all round, no particular scientific reason, I just am......
All down to personal preference and funds at the end of the day!
Users browsing this forum: Bing [Bot] and 68 guests
