RS4 Ceramic Brakes-Rotors don't fit
sonny
RE: RS4 Ceramic Brakes-Rotors don
Post by sonny » Fri Jan 15, 2010 9:57 pm
OK now I could be wrong but I think the Ceramics came in 2 sizes, one for 18'' wheels the other for 19'' wheels. maybe you have the other other, however cant see that effecting the hub circumference.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Jan 15, 2010 10:17 pm
Paul, glad to hear you recieved it. Thanks for the kind words
Hopefully it'll be of some assistance.
Virdee Autos ~ 07950-526592
paku
Post by paku » Thu Jan 21, 2010 6:21 pm
The CD-ROM was very helpful. Unfortunately, they are the wrong discs (part number 4E0 615 301 AA/4E0 615 302C). I'm guessing they are for the A8/S8. Or maybe what Sonny posted is correct? Can anyone verify this?
Will have to go a different route and will keep everybody posted. Thanks.
sonny
Post by sonny » Thu Jan 21, 2010 6:30 pm
sorry to hear this, I have been wondering how you have been getting on, did you purchase the discs new from Audi or second hand, any way of exchanging them?
paku
Post by paku » Thu Jan 21, 2010 6:59 pm
I received the brake set from a friend overseas. It came off of a wrecked Audi, not an RS4 apparently.
I am still trying to get a set for the RS4, the main reason being the weight savings. We track the car quite frequently and it does very well but the weight is fairly evident going throught corners. That is also the reason we are trying to acquire the OEM Euro seats.
Thanks for the concern. I'll post any updates.
sonny
Post by sonny » Thu Jan 21, 2010 7:49 pm
OK yes it is a major weight saving, and most ppl will rip some ones arm off if they had a set of ceramics up for sale lol best of luck.
AntoRS4
Re: RE: RS4 Ceramic Brakes-Rotors don
Post by AntoRS4 » Sun Jan 24, 2010 5:31 pm
sonny wrote:According to my Audi Tech, you will also have to set it up using VAG-COM. the ABS will have to be calibrated to the wipers (so break pads pulsate in the wet when wiper arms activated).
could you please explain how to do it with Vag-com ?
coding for standard rotors is 0004533
what is it for ceramic rotors ?
thank you in advance
sonny
RE: Re: RE: RS4 Ceramic Brakes-Rotors don
Post by sonny » Sun Jan 24, 2010 5:41 pm
"Once fitted the ABS control will need to be re-coded so it knows ceramic brakes are fitted. This can only be carried out at an Audi centre."
This is what my audi Tech said. so not sure if he means VAG-COM. I will have to ask him when he goes back to work.
tabs
Post by tabs » Tue Jan 26, 2010 2:25 pm
Anto I sent you mail already, but for anyone else you wants to carry out this conversion coding is:
0004533 Stock Rotors
0004534 Ceramic Rotors
AntoRS4
Post by AntoRS4 » Tue Jan 26, 2010 5:06 pm
thank you :)
AntoRS4
Post by AntoRS4 » Tue Jan 26, 2010 8:10 pm
0004534 seems to be not the correct one :cry:
somebody here with ceramic rotors fitted and vag-com ?
if yes please select 3-abs and read coding
thank you
paku
Post by paku » Wed Feb 03, 2010 4:16 pm
Sorry I didn't get back to you earlier. Upgrade to new operating system wasn't very smooth so my computer has been down. I usually don't like to bad-mouth anybody, but let's just say the name starts with "W" and ends with "7".
Here are the coding instructions from the CD-ROM:
Coding
Possible ESP versions:
Steel Brakes
Brakes in airbag adaptation channel 51: 22
ESP version: 4533
Ceramic Brakes
Brakes in airbag adaptation channel 51: 20
ESP version: 4534
Hope this helps.
paku
Post by paku » Wed Feb 03, 2010 4:25 pm
Just a side note. Found out the Ceramic brakes are for a A8/S8. So if anybody is interested.....
AntoRS4
Re: RS4 Ceramic Brakes-Rotors don't fit
Post by AntoRS4 » Wed Feb 03, 2010 11:04 pm
paku wrote:Sorry I didn't get back to you earlier. Upgrade to new operating system wasn't very smooth so my computer has been down. I usually don't like to bad-mouth anybody, but let's just say the name starts with "W" and ends with "7".
Coding
Steel Brakes
ESP version: 4533
Ceramic Brakes
ESP version: 4534
Hope this helps.
it works :lol:
thank you paku
B7RS4
RE: Re: RS4 Ceramic Brakes-Rotors don
Post by B7RS4 » Thu May 13, 2010 3:23 am
Could it be as simple as replacing the Hat to get the correct offset??
Users browsing this forum: Google [Bot] and 361 guests
