Gave him a wash
2nd for snow foam, but having used 6 the best I have found was Bilt Hamber. It does work after pressure washing the car with water, then snow foam and then rinse off after a few minutes (enough time to fill your buckets with shampoo).
I will say though that any snow foam does reduce the life of your wax unless you top it up as part of your drying process with something like Duragloss Aquawax or the Autoglym equivalent during these months.
+10P_G wrote:2nd for snow foam, but having used 6 the best I have found was Bilt Hamber. It does work after pressure washing the car with water, then snow foam and then rinse off after a few minutes (enough time to fill your buckets with shampoo).
Just get a good snow foam product, make sure it is at the right consistency. Iv had no problems with mine and has worked wonders
The best method for Snow Foam is to apply it to a dry vehicle, this allows the foam to cling and hence break down the dirt.kenny225 wrote:Snow foam has been great in this weather, I found it works better using the snow foam first then rinsing off, i used to power wash then snow foam, but snow foaming first has produced better results for me and only takes 10 mins to wash.
Absolut rubbish ! My opinion anyway !dest wrote:Looks awesome! There is a black one going around town near me now which must have a Milltek or similar, it sounds insane!
Has definitly changed my view of the V8, Ive never been a fan before....
As for the snow foam, dont waste your money, its way too over rated and pretty much just a gimic to look good more than actually do anything worthwhile
Ive been detailing for a while now, My current car is wearing Zaino AIO, 3 coats of Zaino Z2 pro and a top up with Z8 spray seal. I can snow foam once a week, power wash off, dry, top up with Z8, no need to go near a wash mit !
Snow foam isnt a miricle cleaner but it does lift off some of the grime that causes swirls
Correct ! It clings to the car better, i leve mine around 3-5 mins, pressure rince, etcdibbs26 wrote:The best method for Snow Foam is to apply it to a dry vehicle, this allows the foam to cling and hence break down the dirt.kenny225 wrote:Snow foam has been great in this weather, I found it works better using the snow foam first then rinsing off, i used to power wash then snow foam, but snow foaming first has produced better results for me and only takes 10 mins to wash.
Users browsing this forum: Google Adsense [Bot], QuRace, vailpilgrim and 128 guests
