outside temp sensor
outside temp sensor
my outside temp sensor reading as most is wrong but where is the connector plug where it clips into the loom. my car was worked on by the stains that are unit 20 and the sensor is not in the front bumper anymore where it should be and i cant find it anywhere tucked in, but i thought the connection plug is probably in a fixed place so i will work from the other end- any ideas. thanks
RE: outside temp sensor
Relocating the external temp sensor is a well known solution to the temp being wrong. I've never had any problems with Unit 20, I'm sure they would sort you out if you asked.
Users browsing this forum: No registered users and 55 guests
