what would cause real poor fuel economy??
2.7 V6 30v biturbo - 380 bhp
DutchRS4
Re: RE: Re: RE: Re: RE: Re: what would cause real poor fuel
Post by DutchRS4 » Tue Dec 08, 2009 12:13 am
Coolant temp should be 90 degrees within a few km's of driving and stay there. Good conclusion. Should be your thermostat. Maybe you can find a used one. Good luck!
2001 Avus Silver RS4 with 60k miles
100 cpsi full Milltek
710N DV
Awe Tuning Center Vent Boost Gauge
N249 delete
rickoshea
RE: Re: RE: Re: RE: Re: RE: Re: what would cause real poor f
Post by rickoshea » Tue Dec 08, 2009 1:11 am
it looks like a jammed open thermosat but why 700 quid!!!!??
It's a 4 - 5 hr job - the cambelt has to be removed, therefore it ends up being a complete cambelt change / gaskets / tensioners / water pump. Pain in the ar5e.
When an Audi main dealer perform a complete cambelt change, they do change everything.....apart from the feckin' £10 thermostat. Idiots :bash:
Contigo
Post by Contigo » Tue Dec 08, 2009 9:40 am
Mine in the cold doesn't get up to temp unless idling in traffic but it's running fine and not using any more fuel than normal.
I've spoken to experts about this and they say that the ECU will not overfuel as if it's a cold start if the temp gauge moves off the lowest position. I'm not doing mine until my next cam change is due.
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
DutchRS4
Re: RE: Re: RE: Re: RE: Re: RE: Re: what would cause real po
Post by DutchRS4 » Tue Dec 08, 2009 2:38 pm
Contigo wrote:Mine in the cold doesn't get up to temp unless idling in traffic but it's running fine and not using any more fuel than normal.
That sounds more like a sensor problem. Defect thermostat would keep the needle down at all times.
710N DV
N249 delete
Contigo
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: what would cause rea
Post by Contigo » Tue Dec 08, 2009 7:19 pm
So you are saying that mine could be fixed by a new temp sensor? Ok will get it changed ASAP.
2006 BMW M6 - GONE
rickoshea
Post by rickoshea » Tue Dec 08, 2009 7:28 pm
In my experience, a faulty thermostat will allow water temp to reach 90C when idling in traffic. But when up to speed again will start to drop. A correctly functioning thermostat will allow the temp to reach 90C ( less then 10 mins driving - regardless of hot summer or freezing conditions ) and stay there regardless of caning it / idling / crawling along / constant speed.
maxrs4
Post by maxrs4 » Tue Dec 08, 2009 10:31 pm
NO NO NO NO!!!!!! i just did the cam belt water pump etc like two fooking weeks ago!!! NO NO NO NO!!! FFS!!!
ahhh well i guess i know how it all comes to bits and know its all been free'd off! :roll: :roll: :roll: :roll: :roll: :roll:
bastos
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: what would cause
Post by bastos » Tue Dec 08, 2009 10:38 pm
rickoshea wrote:In my experience, a faulty thermostat will allow water temp to reach 90C when idling in traffic. But when up to speed again will start to drop. A correctly functioning thermostat will allow the temp to reach 90C ( less then 10 mins driving - regardless of hot summer or freezing conditions ) and stay there regardless of caning it / idling / crawling along / constant speed.
this is 100% correct! mine did this too. and is now fixed.. just did the cambelt change last week..
volts
dont be hating.....
Contigo
Post by Contigo » Tue Dec 08, 2009 11:27 pm
Yes that describes the behaviour of my car but mine runs spot on, it gets off the lumpy cold start and runs fine even at say 75 deg on the dial. I get the same fuel economy as I did when I was running with a correct functioning thermostat.
2006 BMW M6 - GONE
drjones1
Post by drjones1 » Tue Dec 08, 2009 11:35 pm
Mine is also identical to what has been described above. I'm not using the car at the moment and will probably do it over Christmas. I dont really like running it below temperature.
A8 3.0TDI quattro sport (every day)
B5 RS4 (the second one)
UR quattro (450bhp)
AC Cobra (replica)
Ford GT40 (replica)
A3 (Wife)
Sit on lawn mower (12hp....)
rickoshea
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: what would c
Post by rickoshea » Wed Dec 09, 2009 12:51 am
Running an iffy thermostat also means that the heater takes longer to start doing it's thing. Oh, and also takes much longer for the oil to get up to full temp too.
maxrs4
Post by maxrs4 » Thu Dec 10, 2009 11:56 pm
where is said thermostat then!?
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Fri Dec 11, 2009 7:53 pm
behind timing belt!
Virdee Autos ~ 07950-526592
maxrs4
Post by maxrs4 » Sat Dec 12, 2009 9:32 pm
well I'm getting fed up with this now!!! the car has now got a new thermostat and its exactly the same!! took me bout 4 hours all in which was good! but its no different! tomorrow i think ill go for a drive with my mates snapon diagnostics machine and log the drive and see whats going on with that! all i can think of now is maf :roll:
Users browsing this forum: No registered users and 26 guests
