Are calipers and rotors interchangeable?
I was interested in running R8 Calipers on a S4 with RS4 2 piece rotors.
Anyone have this done before?
I tried searching but came up with nothing.
I know the part numbers are different but the calipers look exactly the same.
Any help is appreciated.
Happy holidays!
Are the brakes for the RS4 the same as the R8?
- Virdee Autos
- Trader (Expired)
As said caliper looks the same as the R8, maybe different caliper bracket.
Discs are definitely different. They look like the RS6+ jobbies, or more than likely Gallardo discs.
Virdee Autos ~ 07950-526592
If you google the discs then you'll see that although the construction of the R8 and RS4 discs is similiar (split type), the drilled pattern is different.Virdee Autos wrote:As said caliper looks the same as the R8, maybe different caliper bracket.
Are the Gallado discs not drilled and grooved and are 365mm sized.
