Cheepo Exhaust Mod for Xmas....
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
pegbox7
Post by pegbox7 » Tue Dec 01, 2009 12:11 am
Just whilst money is tight and i had a bit of time i decided to see if i could modify the rear boxes on a totally standard system just to give a bit of noise as my standard system was super silent.
I unbolted the system from the KATS back, or should i say had to cut the rotted bolts that hold the sleeves and then it just popped off. Its really heavy and the silencer boxes are HUGE ! I started on the one closest to the kats first and opened it up like a tin by peeling the top side back. in this box was a straight through pipe and a y piece. i totally cut off the box and removed the little joing y piece and left this as a straight through section with no silencer - Job done very easy.
I then moved onto the huge rear box and did the same, slicing open the top section and peeled it away, this was a bit more difficult as its spot welded to a plate/baffel inside but nothing a hammer couldn't rectify. i pulled out wadds of stuffing( Wearing gloves and desposing of this correctly) Once it was totally empty i stitched it back together. I bought 2 x new sleves from a local exhaust place at £1.75 each and it all slid together with ease and fitted straight on the hangers - well thats no surprise as its an OEM system.
Moment of truth as i fired it up and to my surprise/delight it sounded great not too loud and more importantly not like a naff exhaust with no silencers. It now sounds awesome from outside and doesn't boom at all on the motorway, it looks like a stock system but doesn't sound like one.
If i had the money i would definitely buy a Miltek or similar but for now it was a cheap mod that actually has been the most satisfying pound for pound mod that i have ever done....
THE END.... :D
Marshy
RE: Cheepo Exhaust Mod for Xmas....
Post by Marshy » Wed Dec 02, 2009 12:52 am
It was a popular TVR Chimaera/Griffith mod too. Slice open the rear boxes, rip out the wadding, zip it all up again. So what if it's not got chrome tips?
________
Noggy Blue 1999 Facelift S4 with added 'Doug'
(156mph @ VMax, Brunters, 2007-07, pre-remap)
travs
Post by travs » Mon Dec 07, 2009 6:33 pm
Good stuff. Just like gutting precats isn't it?
Written-off: Night Blue Metallic S6 5.2 V10 - Private plate, LED interior kit.
Sold:
Hibiscus Red Metallic S4 (B5 99.5) w/AmD Stage 1 Remap, RS4 Exhaust w/ Gutted Precats & R32 Tailpipes, Afterun Sensor, H&R Coilovers
stimp
Post by stimp » Fri Jan 15, 2010 11:14 pm
That sounds like a really bad idea. Instead of the gases having a direction to flow they will now have all sorts of turbulence one would expect. On motorcross racing four stroke engines you can lose 5 to 10% when the packing gets worn for this very reason. If you keep them wrapped tight the gases come straight out. I expect the outside of the silencers get a lot hotter now as well. Be worth asking the experts if this can do any harm.
