Just about to replace both DV's and am looking for some advise / DIY step by step guide. Ive searched the forums but not had any joy in finding a post.
Any one got an advise on location and removal steps ?
Thanks in advance
Diverter Valve Replacement guide
Re: Diverter Valve Replacement guide
This is link for fitting to S4 assume basically the samebeejay wrote:Just about to replace both DV's and am looking for some advise / DIY step by step guide. Ive searched the forums but not had any joy in finding a post.
Thanks in advance
http://www.stratmosphere.com/HyperBoost ... ctions.pdf
Diesel, fuel of the devil!
- Top Gear
RE: Re: Diverter Valve Replacement guide
Might be worth replacing the small vac lines and clips which go to the T-piece between the two DV's when you do this as well.
I've found leaks here in the past.
What DVs did you put on? 710N? Does anyone know the difference between the 710N and the 710P that I've got on mine?
710P? Never heard of it.Shoppinit wrote:What DVs did you put on? 710N? Does anyone know the difference between the 710N and the 710P that I've got on mine?
Stock is 710A, Audi S3 is 710N, don't you mean Forge 007P?
2001 Avus Silver RS4 with 60k miles
100 cpsi full Milltek
710N DV
Awe Tuning Center Vent Boost Gauge
N249 delete
710N DV
N249 delete
The 710P is what goes on the RS6. Same as the 710N but (I presume) with slightly different spring / diaphragm properties. I was just wondering if anyone knew the difference in driving experience between the two.
Users browsing this forum: Google [Bot] and 30 guests
