Can I still use my RS4's intake manifold if i change to 2.8.
Can I still use my RS4's intake manifold if i change to 2.8 5valve heads? TIA
RE: Can I still use my RS4
yes you can use the inlet manifold on 2.4 and 2.8
1.9TDI A6 are sh*t wrong forum
hi Musty thanks for the info.
so does this mean i can use the heads from a 2.8 in my ASJ(RS4 engine) and not change anything else? TIA
Re: RE: Can I still use my RS4
Do you have the secondry air system on your car? if so you will have to take out the ball bearing out of the hole on the 2.4 or 2.8 as they dont run the secondry air system but aprt form that everything else should be the sametigasTT wrote:hi Musty thanks for the info.
p.s change the exhuast valves to sodium filled ones
RE: Re: RE: Can I still use my RS4
Musty, I have an ASJ engine...I dont know if I have a secondary air system. Thanks for all the help! Cheers!
