Yes they do.aarghesfore wrote:does anyone know if our sidelights have a bulb blown feature?
led drl's
- PetrolDave
Ditto for me. Ordered Wednesday, arrived Friday. Fitted tonight in about 20 mins. Look good. Cheers to Brooner and PRI.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Previous:
- PetrolDave
There's 3 sections to the headlights - indicators on the outside, then the actual headlight (main & dip controlled by a moving mirror) and on the inside the DRL's & sidelights combined.Brooner wrote:may sound like a silly question but were are the side lights cant see any in my headlight?
The DRL bulb is in the centre of the reflector and the sidelight bulb is above it.
Been swotting up on this. Thanks to all who have done the hard work.
As soon as I get back from my next trip I will start swapping out the DRL, Side and number plate bulbs. Anybody done the brake lights? I thought that I read a post where it had been tackled before. Tried looking but couldnt find it. Anybody got any links to the brake lights mod?
Chrisc
Chrisc
Scaghead, I did order those blue sidelights off ebay but they had not arrived before I went away on business on Thursday. I won't be able to try them until next weekend when I am back but will post an update and will put some pics up if they are any good. They do look pretty low rent even on the ad so my hopes ain't high!
cheers fella, even though they are low rent you never know.aarghesfore wrote:Scaghead, I did order those blue sidelights off ebay but they had not arrived before I went away on business on Thursday. I won't be able to try them until next weekend when I am back but will post an update and will put some pics up if they are any good. They do look pretty low rent even on the ad so my hopes ain't high!
Hi, I fitted the blue sidelight bulbs off ebay this afternoon. I think they are pretty good, giving a similar light to the DRLs from PRI. They are very blue when not switched on but it isn't too noticeable as they are so small. Overall I would recommend them. Changing them is a bit like the DRLs, i.e. the passenger side takes about 30 seconds whilst the driver's is much more fiddly. It is a bit easier that the DRLs as they just push back in rather than needing a twist.
I did take some pics in the day but they did not really do them justice, can try at night but as I have done both it won't show the contrast.
Cheers.
Cheers.
done the same this weekend, will get pics up when ive taken them in the dark, i paid £1.99 with free posting for the side lights. well worth itaarghesfore wrote:Hi, I fitted the blue sidelight bulbs off ebay this afternoon. I think they are pretty good, giving a similar light to the DRLs from PRI. They are very blue when not switched on but it isn't too noticeable as they are so small. Overall I would recommend them. Changing them is a bit like the DRLs, i.e. the passenger side takes about 30 seconds whilst the driver's is much more fiddly. It is a bit easier that the DRLs as they just push back in rather than needing a twist.
Cheers.
I went the slightly more expensive route
http://www.priracing.com/product.php/13 ... ulb--pair-
Should see what they are like in the next few days when they arrive and I get around the fitting them. The PIAA DRl ones are great so stuck to the tried and tested.
Users browsing this forum: Zyox and 157 guests
