Starting Problem
Starting Problem
I have done a search but have found nothing that can help. I am hoping one of you guys might be able to shed some light on my issue.
The issue is that when I go to start my car, with ign on and the clutch pressed the starter clicks loudly when I push the start button. I have checked for fault codes and when the car is standing with ign on it doesn't throw any codes. As soon as you press start and the starter clicks as it does it throw up a code - Starter Interlock Signal. If I clear this it does not come up again until I attempt to start. I have tried to bump it which works without an issue and the car runs as normal but the epc light is on.
I know this is quite atechnical question but cannot get any further at the moment.
Thanks in advanced.
Thanks in advanced.
RE: Starting Problem
Clutch pedal switch?
Visit to dealer/independant?
I have looked at the clutch pedal switch but if you dont push the clutch pedal nothing happens at all. Then when you do it just clicks as said so I figured the clutch swithch must be working??
Does anybody know of ay good independents that may be able to help in the south east??
Hey, sorry to hear your are having some problems. My first check would be to charge the battery or jump start with a booster pack. Sometimes everything else will light up okay but there is not enough puff to turn the engine. This can cause the clicking. Failing that its probably the starter that has gone. Hope this might help.
- reevesroadster
I had the same, clicking noise, it was the starter motor, reason: Corrosion due to some thing splashing on the starter motor and alternator caused it to malfunction, prob due to car being in storage for 5 months. covered on warranty. the symptoms described are the same, so im just confident to say its that.RR55FOR wrote:Am based in Sittingbourne, Kent and work near Dover. Why do you say it is the starter for sure then? Has this been heard of? Are there any independents instead of stealers around?
Thanks for replies, much appreciated.
- PetrolDave
dave i think he is based in sittingbourne kent, as posted earlier.
Users browsing this forum: No registered users and 115 guests
