Stupid Q? Headlight dippers....
marb1es
Post by marb1es » Thu Oct 08, 2009 10:52 am
On my previous car (C5 S6 2000) there was a toggle switch next to the interior dimmer to adjust the beam of my headlights.
I now have a C5 03 RS6 and that function is NOT there, I would have thought on an RS this would have been absolutely minimum spec?
Why would a previous customer remove it? And would Audi really manufacture a car without that adjustment setting??
:evil:
GardinerG
RE: Stupid Q? Headlight dippers....
Post by GardinerG » Thu Oct 08, 2009 11:24 am
Xenons are self levelling based on sensors by the 2 near side wheels. To change height you need to use something like VCDS (VAG-COM) to set them into maintenance mode (or similar) then they can be adjusted to the right height. Hence no manual control is required. :thumbs:
HTH
Grant
MartWilliams
Post by MartWilliams » Thu Oct 08, 2009 11:24 am
Mie doesn't have it.
Is it a HID thing, HID lights are supposed to have auto levelling, our lights are hid aren't they?
Golfather
Post by Golfather » Thu Oct 08, 2009 11:25 am
It has been intentionally left blank as the headlights automatically adjust on all cars with Xenons from factory.
If your beam is out of alignment, then it needs to be manually adjusted on the headlamp itself.
spanner1210
Post by spanner1210 » Thu Oct 08, 2009 1:34 pm
Auto leveling?!?! How does it work? is it working all the time as you drive keeping your lights from annoying other people? when i turn the lights on you can see the beam shift upwards!
Is it auto range finding or auto leveling??
Spanner
MUGELLO BLUE SALOON, 2004, STANDARD AT THE MOMENT
Post by Shoppinit » Thu Oct 08, 2009 7:06 pm
There are sensors on the control arms to tell the car how level it is (or isn't).
marb1es
Post by marb1es » Sat Oct 10, 2009 8:25 pm
8) Nice one lads all very helpful info here. Thanks for the tips, Im going to get her to MOT centre and see if they can do a quick allignment. They are seriously too low and not moving when driving as they should if auto...Sensors must be up the wazoo! :evil:
GardinerG
Post by GardinerG » Sat Oct 10, 2009 9:00 pm
Sounds like the system hasn't been set up correctly marb1es. Quick question but do you still have DRC?
Have a look here: http://www.ross-tech.com/vag-com/cars/x ... nment.html and note the following:
Rosstech wrote:There have been reports of lowered vehicles displaying an error message in either Basic Settings group 001 or 002. If the vehicle height sensor(s) are bottomed out, it may be necessary to bend the sensor bracket to allow normal adjustment to occur.
I had this with mine before the suspension was raised again.
HTH
Grant
Post by Shoppinit » Sat Oct 10, 2009 10:35 pm
Also, what can happen - if care isn't taken when changing the suspension - is that the lever can pop round the other side. If you see what I mean.
Be careful in basic settings. When you go from group 1 to 2 in xenon range, you are telling the car to learn the new position.
drybeer
Post by drybeer » Sun Oct 11, 2009 7:15 pm
I think your car could have a broken control arm then - if either one is broken then the lights have an emergency "default" to the lowest - so at least you are not dazzling other road users if the system is faulty - I could be wrong but that's what I think it is.
So - I think the MOT station will not be the correct option - you need to find out which (or maybe both) arms need replacing, and then it should work?
Maybe.
Users browsing this forum: Bing [Bot] and 53 guests
