Car feels slow... Oh no, it *is* slow!
RE: Re: Car feels slow... Oh no, it *is* slow!
Post by Shoppinit » Wed Oct 07, 2009 9:52 pm
Right. After changing my plugs. I'm getting fairly consistently:
0-60: 5.3s
30-70: 4.2s
What are your thoughts on those figures?
andyt
Post by andyt » Wed Oct 07, 2009 11:45 pm
When I tried 0-60 times with a GTech Pro, I usually got 5.5ish, once managing 4.8. It just felt like I could never get off the line sharply enough due to the autobox.
Stigter
Post by Stigter » Wed Oct 07, 2009 11:55 pm
Mafs??
andyt
Post by andyt » Thu Oct 08, 2009 1:49 am
In my case it wasn't that long after it'd been on a rolling road, showing a healthy output. I don't get why a car would do this anyway - learn how you drive and then turn the power down accordingly. Surely if that's the way I drive, then I don't need it to do that?
Post by Shoppinit » Thu Oct 08, 2009 8:02 am
Andy, I agree. I disconnected the battery and it made no difference. I didn't really think it would.
It definitely feels like the box slowing things down. Maybe it's limiting the torque in 1st. I don't really care about 0-60 times, I just wanted to use the number as a benchmark to test the health of my car.
I wondered for a while if the g-tech was accurate or not, but the runs I did last night were with the g-tech and vagcom in parallel with the g-tech speed marker set at 70mph as well as the RS6 speed warning at 70. Both went off at the same time and the numbers are close.
Stigter, if it were the MAFS, wouldn't I be getting DTCs?
I would have thought a boost leak was more likely, but looks like the car is boosting correctly.
grizz
Post by grizz » Thu Oct 08, 2009 8:19 am
Maffs wont show a DTC.
Check block 032 , This will show any boost leaks.
Unit 20
0151 3366888
jd_hants
Post by jd_hants » Thu Oct 08, 2009 10:27 am
Would it be a good idea to have a sticky which lists which area of VAGCOM can be checked for various things. I guess these are probably listed somewhere anyway, or a search on the RossTech website would give some pointers???
Post by Shoppinit » Thu Oct 08, 2009 11:49 am
The ross-tech website is distressingly sparse in terms of information. Especially for the C5 A6. More stuff for the A4. It's very frustrating, and I rarely bother to even look at their wiki anymore.
The actual software is well done, however, and it simply takes a few moments to scan throught the different measuring blocks, all of which are labelled and explained dynamically.
Re: RE: Re: Car feels slow... Oh no, it *is* slow!
Post by Shoppinit » Thu Oct 08, 2009 12:36 pm
grizz wrote:Maffs wont show a DTC.
How does this look? I don't really know what I'm looking for.
alpinestars
Post by alpinestars » Fri Oct 09, 2009 6:56 pm
Shoppinit wrote:Right. After changing my plugs. I'm getting fairly consistently:
0-60: 5.3s
30-70: 4.2s
My 30-70 times are around 3.6 3.7. If I recall correctly the times that EVO mag got were around 4.5s.
RE: Re: RE: Re: Car feels slow... Oh no, it *is* slow!
Post by Shoppinit » Fri Oct 09, 2009 7:10 pm
Thanks for that. Are you running any mods?
Post by Shoppinit » Fri Oct 09, 2009 9:10 pm
jd_hants wrote:Would it be a good idea to have a sticky which lists which area of VAGCOM can be checked for various things. I guess these are probably listed somewhere anyway, or a search on the RossTech website would give some pointers???
If you can find a way to make stickies, I'll be interested to know!
In the meantime, this sounds like what you're looking for:
http://www.goapr.com/support/datalogging.php
mushdaffer
Post by mushdaffer » Fri Oct 09, 2009 9:19 pm
what gear are you doing the 30-70 in. Is it in "S" mode and booting it in 2nd ?
RS6 Plus (Black)
Post by Shoppinit » Fri Oct 09, 2009 9:21 pm
Starting in 1st for the 30-70. I've tried S and tiptronic. No difference.
mushdaffer
Post by mushdaffer » Sat Oct 10, 2009 8:34 am
I will give it a bash on Monday on my trip to manchester - famous old stop watch though so will do a a few runs to get an average !
RS6 Plus (Black)
Users browsing this forum: Google Adsense [Bot], pwack, Shoppinit and 58 guests
