Disabling Passenger airbag?
Hi
Looking to install a switch to allow the front airbag to be switched on / off (thus allowing a booster seat to be used for my boy).
Has anyone done this before?
If the airbag is diasabled will it raise a fault code?
Any help much appreciated!
Barrie
Barrie
RE: Disabling Passenger airbag?
I think you can disable the front passenger airbag using your key. IIRC the switch is in the glovebox?
aarghesfore
My previous car was an A4 Quattro sport. That didn’t come with a switch to turn off the front airbag so I had one fitted at Wimbledon Audi. As the other guys say it was operated with the ignition key. From memory it was about £150 to have it put in but that was about 5 years ago.
I did notice that my RS4 does not have one which I did think was a little odd for a top of the range car. Luckily I don’t need it now my kids are a bit older.
- Christiaan
- 1st Gear
If I rememer correctly it is seat specific.
I think it is not recommended to have a rear facing child seat in the buckets, therefore no reason to have the disabling system.
I think you had to spec Isofix and Recaro's
ETA....
Just checked the original brochure and on pag 15 it states:
ISOFIX child-seat preparation, for front passenger’s seat and outer rear seats, including passenger airbag deactivation switch.
Only in combination with Recaro Sports Seats (No cost option)
ETA....
- PetrolDave
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 148 guests
