Removing front door cards
alpinestars
Post by alpinestars » Tue Sep 22, 2009 3:22 pm
Can anyone tell me how do to this please? I know there are screws in the side at the top, but I can't see anything else that holds them in but can't take them off either!
rob8457
RE: Removing front door cards
Post by rob8457 » Tue Sep 22, 2009 3:44 pm
Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
PoRToS
Re: RE: Removing front door cards
Post by PoRToS » Wed Sep 23, 2009 10:12 am
rob8457 wrote:Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...
GardinerG
Post by GardinerG » Wed Sep 23, 2009 10:36 am
PoRToS wrote:Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...
This is usually caused by the plastic window guides breaking. It's a common fault on the A/S/RS6. :roll:
alpinestars
Post by alpinestars » Wed Sep 23, 2009 12:35 pm
Bobby
Thanks Bobby, will try this tonight.
SimonY
Post by SimonY » Wed Sep 23, 2009 1:30 pm
Guys,
I had to do this earlier this year cos of a rattle and on searching YouTube also found this via a search on "Audi A6 Power Window Repair"
http://www.youtube.com/watch?v=9UP1Rn7Wj3s
It really is a piece of cake!
Simon
Current
1985 Ur quattro in Alpine White
Previous
2004 RS6 Mugello Blue Avant | Milltek Non-Res | Bilstein PSS9 Coilovers | Hotchkis ARB | Black Optics Kit | RS6+ Coloured Alloys (Sold but never forgotten)
2015 RS4 in Riviera Blue
2016 RS6 in Utopia Blue
2002 S3 in Imola Yellow
GarethRS
Post by GarethRS » Wed Sep 23, 2009 3:33 pm
The hardest part is getting the window switches out, once you have mastered it, its very easy.
Let me know if you get stuck as I have some pictures.
GardinerG
Post by GardinerG » Thu Sep 24, 2009 4:02 pm
If anyone needs the part number of the pink plastic window guides it is 4B0 837 463B (when I ordered them from VAGParts in the good old days! :D )
Users browsing this forum: Lander91 and 53 guests
