Removing front door cards
Can anyone tell me how do to this please? I know there are screws in the side at the top, but I can't see anything else that holds them in but can't take them off either!
RE: Removing front door cards
Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
Re: RE: Removing front door cards
Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...rob8457 wrote:Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
This is usually caused by the plastic window guides breaking. It's a common fault on the A/S/RS6.PoRToS wrote:Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...
Thanks Bobby, will try this tonight.rob8457 wrote:Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
Guys,
I had to do this earlier this year cos of a rattle and on searching YouTube also found this via a search on "Audi A6 Power Window Repair"
http://www.youtube.com/watch?v=9UP1Rn7Wj3s
It really is a piece of cake!
Simon
Simon
Current
1985 Ur quattro in Alpine White
Previous
2004 RS6 Mugello Blue Avant | Milltek Non-Res | Bilstein PSS9 Coilovers | Hotchkis ARB | Black Optics Kit | RS6+ Coloured Alloys (Sold but never forgotten)
2015 RS4 in Riviera Blue
2016 RS6 in Utopia Blue
2002 S3 in Imola Yellow
Previous
The hardest part is getting the window switches out, once you have mastered it, its very easy.
Let me know if you get stuck as I have some pictures.
If anyone needs the part number of the pink plastic window guides it is 4B0 837 463B (when I ordered them from VAGParts in the good old days!
